Atilla the Fun wrote:Getrags have one other failure point. In the bellhousing area, that flat pad at about the 10:00 position. The bearing inside of there can push through.
I've seen that happen, but I think that's a casting defect related to the shape of the structure around that area.
The axial load from the final drive mesh actually pushes the output shaft the OTHER way, away from the part that breaks. The only way to apply load to that part of the case is to dump the clutch in reverse.
