Moderators: The Dark Side of Will , Series8217
admin
Admin is not Howard
Posts: 65 Joined: Wed Dec 31, 1969 7:00 pm
Post
by admin » Wed Sep 03, 2008 6:13 pm
I am creating this thread for you so you can post all your questions and problems in this one thread.
Lowlux, no more reason for you to start any new threads. You have your own sticky thread now to put everything in so its easier to keep track of.
If you start new posts with questions, they will be deleted and moved to this thread.
I just thought I would make it easier for you and everyone to keep track of what you are working on and having problems with.
Boscolingus
Posts: 448 Joined: Sat Dec 16, 2006 8:38 pm
Post
by Boscolingus » Wed Sep 03, 2008 8:01 pm
well, it was - then you simply laid your tools upon it. Sell the car, put funds in trust fund, kill yourself, let next of kin to use funds for burial ( min $300 ).
Have a geat day. :thumbleft:
A.K.A. Chicken McNizzle on Old Europe
Posts: 8371 Joined: Fri Nov 19, 2004 7:12 pm
Post
by Shaun41178(2) » Wed Sep 03, 2008 8:11 pm
lowlux wrote: i can not drain the oil.... oil pan bolt stripped.
this is got to be the greatest car ever built.
I wouldn't be surprised if you were using the wrong tool to try and take it off.
whipped
Posts: 4719 Joined: Tue Mar 22, 2005 11:17 am
Post
by whipped » Wed Sep 03, 2008 9:04 pm
You're doing it wrong.
righty tighty, lefty loosey.
Post
by Shaun41178(2) » Wed Sep 03, 2008 9:53 pm
I am so glad all his posts will now be contained in one thread.
Kohburn
FierHo
Posts: 4748 Joined: Fri Apr 01, 2005 10:15 am
Post
by Kohburn » Thu Sep 04, 2008 8:11 am
whipped wrote: You're doing it wrong.
common mistake for beginners, sometimes a costly one.
Nashco
Posts: 408 Joined: Fri Jun 22, 2007 12:58 pm
Post
by Nashco » Thu Sep 04, 2008 9:35 am
At what point will you just take the car to a mechanic or sell it? You obviously have no business trying to repair it on your own, not because you don't know what you are doing but because you refuse to learn and instead just come on the internets bad mouthing the car and the people trying to help you. You can't even change your own oil without disaster, so to be trying to actually fix the car is obviously beyond your abilities right now. If you don't know anybody who can help you learn how to work on your car locally that can put up with you, then you need to take it to a mechanic or sell it.
Bryce
Xanth
Posts: 637 Joined: Fri Sep 15, 2006 8:40 pm
Post
by Xanth » Thu Sep 04, 2008 9:42 am
How long did you run the car without the belt on anyway?
You might have a bad head gasket, I highly doubt you'll want to tackle that job.
Post
by Shaun41178(2) » Thu Sep 04, 2008 12:15 pm
buy a new belt and put it on and tighten it.
Did you ever go buy a haynes manual or go to fieroaddiction.com and download a free owners manual like we told you to do?
Boscolingus
Post
by Boscolingus » Thu Sep 04, 2008 7:46 pm
well then, that leaves the question of literacy
lucky
Posts: 894 Joined: Thu May 17, 2007 11:16 pm
Post
by lucky » Fri Sep 05, 2008 1:07 am
He can kinda type....that implies some level of reading comprehension.
There's lotsa pictures to look at too, that's always a bonus...... :dontknow:
Xanth
Post
by Xanth » Sun Sep 07, 2008 3:59 pm
You need to take loosen the lower bolt if its there. If its not, you should be able to loosen the upper bolt then swing the alternator inwards.
lucky
Post
by lucky » Sun Sep 07, 2008 10:29 pm
Top bolt always strips in that bracket. Take the bracket off, drill out the threads and get a bolt 1/2" longer and a nut; problem solved.
lucky
Post
by lucky » Mon Sep 08, 2008 1:44 am
It's a fun design, but it's cheaply made. It's 80's america at it's best. The motor's got potential, but it's failure prone. The Fiero is an ongoing struggle for survival. Either commit now or :stfu: .
Posts: 3289 Joined: Wed Mar 30, 2005 2:37 pm
Post
by p8ntman442 » Mon Sep 08, 2008 9:18 am
lowlux wrote: i will be working on this god damn son of a bitch forever before i sell it.
thats a free lesson.
Xanth
Post
by Xanth » Mon Sep 08, 2008 9:47 pm
I'll take it, give me one day and I'll have the engine out and a new one in.
Xanth
Post
by Xanth » Mon Sep 08, 2008 11:16 pm
For one thing, if the bolt is spinning and not coming out, then there are no threads. If there are no threads, that bolt can be yanked out. You may be able to pry behind the head with a thin flathead screwdriver to pop it out some. Then grab it with pliers try and work it out. Be careful, can hurt your hand pretty good if you slip off the bolt.
I haven't had the alt bracket off on my car, not sure what's involved.
lucky
Post
by lucky » Mon Sep 08, 2008 11:19 pm
I would use a punch and a hammer to knock the bolt out from the backside.
Fastback86
Posts: 1010 Joined: Sat Mar 04, 2006 12:19 am
Post
by Fastback86 » Mon Sep 08, 2008 11:29 pm
At least 4 bolts, maybe 5, I don't recall.
<Insert Sig Here>
Posts: 15630 Joined: Wed Nov 24, 2004 11:13 pm
Post
by The Dark Side of Will » Tue Sep 09, 2008 7:41 am
The alt bracket picks up three bolts on the head and one of the engine mount bolts.
