Aarons turbo setup > My turbo setup...
Ok so I was playing around with some stuff today. I disconnected the top port of the WG, and made some runs. Guess what, boost holds solid just off the spring/bottom port.
Stupid me hooked up the solonoid wrong so that when it was commanding more duty cycle, it was actually putting more boost to the top of the wg (keeping it closed). Opps.
Well my 3.3bar will be here tomorrow anyways.
Wow, I really screwed up. The figured the GM sensor I bought would be really nice because its a direct replacement for the stock 1bar map that is just hanging out in my intake. I could just clip it in there and get rid of the big rectangle map that I have ziptied to the plenum.
Turns out the new MAP sensor only reads down to about 40kpa or -8.9 psi. Unfortunately, I see more vacume than that. Looks like this bitch is getting returned tomorrow.
Shoulda checked the datasheet, mang!
http://delphi.com/shared/pdf/ppd/sensors/et_turbo.pdf
You got one of these I would guess?
I could maybe get by hoping i don't see any cruise loads less than what the sensor would read.
The problem is that the highest kPa the AEM will allow is 32.77 at 1v. When I ever I try to enter 40kPa for .1v, the program beeps at me and defaults back to 32.77.
Bah, I'm just going to return it for the other big rectangle GM 3 bar. I don't need the extra .3, i was just hoping to use this style without actually thinking it through first.
The factory computer doesn't cut the injectors throughout the decel stage though. In fact, at about 2500rpm, it starts to slowly phase them back in. By 2,000rpm, they are back to fully operational, and holding a steady 14.7 AFR. This helps the car come to an idle without dipping or stalling, and helps the engine react smoothly when you get back onto the throttle.The Dark Side of Will wrote: If the only time you see lower pressure than the lower limit of the sensor is on deceleration, then zero out that part of the map and have DFCO.
I wouldn't think he'd need to hackjob his tune, on such a Godly factory computer, right Will?
Factory ecu's fully cut injectors during decel. There is a table that works with the IAC that introduces small amounts of fuel when the rpms get near desired idle. Desired idle is quite dynamic on my tunes, manual or auto, it is not stock, and desired idle is based on VSS. High VSS = high idle, I usually try to keep it a few hundred RPM under what it should be seeing at that speed. IE 70mph = 1900 desired idle for my auto, and ~2500 for my manual cars. This gives you excellent decel characteristics, and prevents stalling 110% of the time (the extra 10% is there because on the manuals you can roll start them from like 2mph with these settings.)
I already spent a good 8hrs or so setting up my decel fuel cutoff so it is a very smooth transition in my light cruise throttle range.
With the first base map, I would get a slight surge as the car would switch between different parameters of either cut off or reintroducing fuel. It is now tuned really well and the transition can't be felt by the passenger. The car is really smooth in those areas.
Aaron, its good thing I'm not using a "Godly factory computer" otherwise I would have other MAP based issues... (and MAF too considering I don't have one)
The "turbo pressure sensor" came in today, and is ready for return. I have also already ordered the typical 89 turbo trans am 3bar, and will have it on monday.
My modded maf setup is working FLAWLESSLY its so great! Been doing 20 degree starts up here in the great north, and its performing great! Idle is dead steady at 670rpms warm even.Jinxmutt wrote:I already spent a good 8hrs or so setting up my decel fuel cutoff so it is a very smooth transition in my light cruise throttle range.
2 bar maf, that just gets maxxed instantly when I make boost, is not hurting me at all.
