I'd like to find a hub that will fit the existing upright, even if that includes having to machine out the center a bit. I think I might end up being limited by the bolt circle of the 3bolt mounting flange. Here are the specs that I have for the 88 rear hub.
Code: Select all
Attribute Value
Flange Diameter 4.921
Bolt Circle Diameter 3.937
Bolt Circle Diameter Metric 100
Bolt Size M12X1.5
Bolt Quantity 5
Wheel Pilot Diameter 2.244
Brake Pilot Diameter 2.274
Flange Offset 1.66
Hub Pilot Diameter 2.795
Hub Bolt Circle Diameter 4.016
Bolt Hole MET 12.96
Bolt Hole qty 3
Number of Splines 33
Flange Shape MODIFIED TRIANGLE
This is the difference between the S10 and the fiero, from bubbajoe's site..
I think running that larger outer would help prevent breakage. I know the S10 necks down right where I've broken the axle, but that picture is just for example...
