My NEW fiero turbo setup
Re: My NEW turbo setup
maybe taper is the wrong word. Bevel might be better. There is a bevel on the butterfly where it seals against the side of the runner. The guy at the machine place measured it but I forget the degree he stated. it might be on a notecard but ill have to double check.
as long as it's for the right size bore, I can't see the taper being that big of a deal. I do know a higher angle on the leading edge will make for a touchier/ snappier throttle then a shallower angle.
Shaun41178(2) wrote:maybe taper is the wrong word. Bevel might be better. There is a bevel on the butterfly where it seals against the side of the runner. The guy at the machine place measured it but I forget the degree he stated. it might be on a notecard but ill have to double check.
It's not a taper. It's a bevel, and the bevel is the opposite direction on opposite edges of the plate. That's so it can sit at a slight angle in a parallel bore and not get jammed closed.
Exactly, where I took it they said the couldn't duplicate it with their machines
It requires making a fixture that's something of a PITA to make.
Maybe Steven could 3D Print one...
Bump for updates?
Another bump for updates...
Where's the 500 RWHP dyno sheet?
no updates.
CincinnatiFiero
Post by CincinnatiFiero »
SHAUN HAS BEEN WORKING ON THIS FOR TWO YEARS AND COUNTING
semi recent pic of how I routed the charge piping without the t-bolt clamps. No intercooler in this pic but it will be hooked up with more boost. wastegate is at 3.5 psi right now but changing that out and looking at 80lb/hr injectors too.
CincinnatiFiero wrote:SHAUN HAS BEEN WORKING ON THIS FOR TWO YEARS AND COUNTING
:lol:
I almost died!
http://60degreev6.com/forum/showthread. ... ITB-intake
itb intake cast to line up with gen 2 heads. might be able to port to line up with gen 3 heads since the roof was raised in gen 3. not sure.
https://www.youtube.com/watch?v=LNbOXSFBNis
https://www.youtube.com/watch?v=jLikjChQlPE
here is a pic
http://realfierotech.com/phpBB/download/file.php?id=204
http://www.shaun.saturnet.net/pics/3500.JPG
asking $2k with everything to bolt on. 24 or 36lb injectors, fuel lines, fpr, vacuum lines, yadda yadda
$1400 bare
matching heads ported by katech with ti retainers that flow 223 cfm on the intake are $600. Also has crane gold race roller rocker 1.5 ratio
3500 long block with WOT cam with .500+lift will be $3k for it all with aluminum flywheel
so I take it we will never see a pass or a dyno on this engine? :(
ericjon262 wrote:http://60degreev6.com/forum/showthread. ... ITB-intake
here is a pic
$1400 bare
Bump...
Emc209i
Post by Emc209i »
No intercooler?
I have an intercooler. That pic is 7 months old and was only done as a mock up and photo op
Lol
Shaun41178(2) wrote:I have an intercooler. That pic is 7 months old and was only done as a mock up and photo op
Where's the 500 RWHP dyno chart?
must not have seen my latest video. i posted it about 7 months ago.
https://www.youtube.com/watch?v=M8xaHebT4DU
how does an idle video mean the car makes 700 hp? does that mean my car makes 550hp? the only dyno run on that youtube account is an iron head 3.4, hardly 700 hp...
:no:
Shaun41178(2) wrote:must not have seen my latest video. i posted it about 7 months ago.
A) I want my 0:28 back (Didn't bother to watch the whole thing)
B) That video contains neither a 500 HP dyno pull, nor opening a can of whoopass on the variety of car which would indicate that said Fiero had 500 RWHP.
