LX9Alpine wrote: ↑Wed May 22, 2019 3:51 pm Hello all! Thanks for posting all the info on your build! After investigating the DIY Autotune products, I purchased the microsquirt and harness. Its been a while since I was fresh on all the requirements I thought I needed, but you are saying that your MS wasn't enough? I have an LX9 with custom headers a T5 five speed and a Holset HX40 turbo I'm putting into an old sports car. You can see it here lx9alpine.com
First off, welcome to the board, cool build!
no, the megasquirt should be fine, I wanted to get a MS3 pro ultimate for a few reasons though.
with the MS3 pro, I can directly input my VSS, oil pressure, coolant temp, and all other parameters to the MS3Pro, and display them on a digital dashboard via canbus, instead of having all of them interface with the car. this eliminates a large amount of wiring that otherwise has to make its was into and out of the car, removes many potential failure points, and reduces weight of the car. I'm thinking about using can bus and microsquirts to work as a BCM as well, so I can datalog wheel speeds, fuel level and control components like the intercooler pump and fuel pump, which are on the body instead of the engine.
the MS3 Pro is also a much more robust unit, that is weather resistant, and much more vibration resistant than the regular MS3.
I know MS3 can run the LX9 native, without an external trigger now, using the beta firmware release. I am not sure is a microquirt can or not, I haven't looked into it yet.
here is some info for the MS3 LX9
http://www.msextra.com/forums/viewtopic ... 31&t=70646
