The purpose of this section is to talk about track setups.
Be It autocross, Dragstrip, SCCA, or other form of racing.
Things that should be talked about are.
Engine mods,
Suspension mods, coilovers, lowering springs.
Alignment settings, Camber and Castor Toe In.
Dyno numbers, Dyno proveable mods and their results.
Race tires, Or sticky street tires
Weight reduction,
Weight transfer including lightening of the car and the weights of each object(s)
Clutch setups.
Pretty much anything that can be shared between us that actually race their cars.
The more technical the better. Also the more scientific of testing of before and after tests should be number one priority. NO MENTION OF BUTT DYNOS to be mentioned here. This is a blasphemous term here in this section. Only real hardcore data is to be expected.
Thanks
Admin
The purpose of this section.
