88 wheel bearings
88 wheel bearings
I know this was an issue a few years ago... But has anyone ever found a replacement or a cache of NOS bearings? :scratch:
'cos if I could fine 4 of 'em, I'd be all over that shit.
Rear's are the same as the 84-87's and AFIK they are still available. check the Fierostore, or autozone, I think they were a commonly used wheel bearing.
I've had to replace wheel bearings on EVERY used car that I've ever owned...
Constant-wear item, although they are usually good for at least 100,000....
Still, nice to know I can get ahold of some. It's the only real thing holding me back from buying an 88. But I kinda want the suspension.
its the front wheel bearings i thought people complained about on the 88Mach10 wrote:I've had to replace wheel bearings on EVERY used car that I've ever owned...
The aftermarket 88 front bearings are complete crap.
Theres a set of 88 front bearings on a coupe at the U-Pick-U-Save in Wilmington, CA if anyone needs a set of factory ones.
You can machine the front 88 knuckle to take a rear Fiero bearing, just stick a bolt through the hub/bearing in place of the axle so it doesnt fall apart.
We're looking into some alternatives at WCF, I'll let you guys know if we come up with anything else.
the solstice sky hubs wouldn't happen to use the same axle spline would they? those bearings don't need a bolt through emSeries8217 wrote:The aftermarket 88 front bearings are complete crap.
only downfall would be the new bolt circle
The bolt pattern can be redrilled quite easily. However, the centerbore is also much larger, so you wouldn't be able to fit your stock brakes or wheels. That's the biggest problem..Kohburn wrote:the solstice sky hubs wouldn't happen to use the same axle spline would they? those bearings don't need a bolt through em
What about hacking up a set of axle shafts to occupy the space? Dunno where I'd even start in looking for a bolt with the right thread, splines, and metallurgical properties.... :scratch:
Given the option of a $15 set of junkyard axles and $110/ea wheel bearings, a hacksaw, and an hour's worth of machine time...
Compared to $400 (us, + shipping) for a set of supposedly useless aftermarket bearings...
And given that I'm not too shit-hot on the idea of spending $500 each on a custom knuckle to use $30 bearings....
Seems to me that as long as the bandaid is a) safe, b) reliable, and c) attainable... I try not to be a cheapass mofo, but I AM a cynic and enough of a pragmatist to accept a workable and viable solution.
Regardless of how boring and uninspiring it might be.
