Page 8 of 12
Re: lz9 3900 V6 buildup
Posted: Thu Jul 15, 2021 6:57 pm
by CaptainHindsight
Nice find! Thanks.
Posted: Sat Jul 17, 2021 5:37 pm
Cerakoted hot parts. Can do more. Lmk if you have anything you want coated.
- 20210717_155550.jpg (3.32 MiB) Viewed 5662 times
Posted: Sat Jul 17, 2021 9:33 pm
Nice! Did you spray & bake yourself?
Posted: Sat Jul 17, 2021 9:43 pm
Yes
Posted: Mon Jul 19, 2021 1:50 am
by Honest Don
Cerakote looks pretty good! Specs on the whirlydoo?
Posted: Mon Jul 19, 2021 3:00 pm
Its a borgwarner s372
Posted: Tue Jul 20, 2021 10:30 am
by Honest Don
Exciting!
Posted: Sat Jul 31, 2021 1:21 pm
New turbo is in.
- 20210731_130617~2.jpg (1.63 MiB) Viewed 5588 times
Posted: Sat Jul 31, 2021 1:24 pm
- 20210717_170130.jpg (4.34 MiB) Viewed 5588 times
Posted: Sun Aug 01, 2021 10:08 am
The Dark Side of Will wrote: ↑Wed Jul 07, 2021 2:15 pm
VHVHVHVHHVHVHVHVHVHVzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzt
Going for 600 at the wheels?
Posted: Sun Aug 01, 2021 2:02 pm
Yea
Posted: Sun Aug 01, 2021 4:34 pm
by eHoward
Way to go Shaun! looking good!
Posted: Sun Aug 01, 2021 8:34 pm
Thanks Howard.
I got a datalog to share of the 72. Its a tad laggier but I can tune it better to bring boost in sooner. Its about 500 rpm slower or so which isnt terrible.
67mm on top. 72mm on bottom
- Message_1609194682720.jpg (861.32 KiB) Viewed 5554 times
- 20210801_202131~2.jpg (1.85 MiB) Viewed 5554 times
Posted: Sun Aug 01, 2021 8:42 pm
What tuning suite is that?
Posted: Sun Aug 01, 2021 8:59 pm
Its mega log viewer that diy autotune
Posted: Tue Aug 10, 2021 5:58 pm
Carnage.
Went to fire it up the other day to take around the block. Heard a loud bang and then subsequent bangs while cranking. I wasnt sure what it was until I pulled the engine.
I thought maybe a rod bolt came loose or something as it was dependent on rotation.
I pulled the engine, set up the starter on it and applied power. The starter was making noise each time the gap in the flywheel came around as the gear disengaged and engaged.
I ordered a new steel flywheel from autozone for 65 bucks. A new aluminum one is about 400 shipped. I'll play around later and see if I can reinstall a new ring gear on this aluminum flywheel.
- 20210810_175113~2.jpg (1.54 MiB) Viewed 5517 times
Posted: Tue Aug 10, 2021 7:17 pm
by pmbrunelle
Do you know what could have caused that?
Posted: Tue Aug 10, 2021 7:37 pm
That's really F'in weird on a unit that new. How does the starter gear look? Can you look at the root clearance at the starter mesh? The most likely cause this soon in the life of the part is that the starter isn't correctly shimmed.
I wonder if they snagged a Pioneer ring gear or made their own. You could try a Pioneer ring gear.
Posted: Tue Aug 10, 2021 10:56 pm
by Honest Don
Bummer. How does the gear on the starter look? Did it ever feel like it was kind of kicking back when cranking over?
Posted: Wed Aug 11, 2021 9:16 am
Starter appears to mesh well. Starter teeth look good. No idea why this happened but it did. Its a relatively easy fix
