Wheel h-h-h-h--h-h-h--h-h-h-h--h-hop!
befarrer
Post by befarrer »
I get wheel hop....Oh wait, it is just the miles of washboard in this town.
Jinxmutt
Re: Wheel h-h-h-h--h-h-h--h-h-h-h--h-hop!
Post by Jinxmutt »
Series8217 wrote: Tires are 255/40/17 Pirelli P7000s on the rear.
Wow, reading comprehension owns me.
whipped
Post by whipped »
befarrer wrote:I get wheel hop....Oh wait, it is just the miles of washboard in this town.
:withstupid:
Replace "washboard" with "potholes"
:thumbleft:
whipped
Post by whipped »
Do you have rubber suspension or motor mounts? Maybe your engine is flying around...
whipped wrote:Do you have rubber suspension or motor mounts? Maybe your engine is flying around...
Suspension is all poly. Cradle is solid mounted (88). Engine is mounted with 4 stiff rubber mounts (Dodge Truck mounts, Anchor p/n 2265), with a torque strut similar to a swaybar endlink (with poly bushings). There isn't any movement there as far as I can tell.
It's not simply movement that contributes to wheel hop... it's lack of damping; if your engine mount system can store energy and doesn't have much damping associated with it, then it might be contributing
I'd do the Konis before I got worried about that, though.
Well thats certainly a possibility then. I want the Konis anyway though so I'll get those first and then add another torque strut; maybe even a driveline damper of some sort.
As long as your engine's reasonably well mounted, it's probably not an issue. Bet you $1 the Konis fix it.
