I'm currently racking my brain trying to find the best place to mount the new MS3 pro, I think I'm going to hack the back out of the console and mount it where the stock ECM went, but I'm still contemplating mounting it in the engine compartment near where the stock battery tray was.
I really wanted to run a pi dash, but I don't think I'll be able to, mainly because the Fiero dash won't fit a reasonable size display without enlarging it quite a bit, and I would rather not take on a project like that yet.
one of the other goals of this teardown and rebuild, was to convert to DBW. I hated on DBW quite a bit when I started this swap years ago, but I like it more and more. especially because it opens a ton of doors for different modes of traction and launch control, I'd also bet that I could make a "valet mode" that limits throttle position.
unfortunately, I didn't realize that the MS3 Pro doesn't support DBW by itself and requires an add on controller. a guy in Finland came up with this:
https://www.dbwx2.com/
it's about $385 not including shipping.
https://shop.protoparts.fi/product/798/ ... country=us
it appears to offer pretty good response. I've got a 75mm LS4 TB on the way from Fieroguru that I'll adapt to a manifold, either my custom one, or a one of the plenums I have sitting around the house. my Custom plenum needs work to be made right though, the welding shop who put it together for me warped the hell out of it, I had it machined "flat" and then none of the bolts lined up, so I'll probably ditch it and start over. another plus to DBW will be packaging. the throttle cable had to run over the top of the plenum, and the LS1 TB I have, has a huge 4" mouth on it, so it required special adapters to make the charge piping fit right.
I'm also trying to have a non-lift-off decklid again, I am both glad I cut the hinge boxes out, and with I hadn't. if I can find a new decklid that isn't butchered like mine is, I'll make a set of hinges like Fieroguru made for his car.
http://www.fiero.com/forum/Forum1/HTML/085829.html
it'll be easier to access spark plugs, and I'll regain a functional trunk of sorts. in doing this, I will have to swap the intake manifold to point towards the transmission, but I think that will only help many of the other packaging problems I have, and make getting AC back way easier. it should also help the engine come onto boost sooner, by shortening the intake tract.
