If anyone here knows where I can get one I need a fiero getrag slave arm. The one on my fwd trani is too short.
I already asked Matt, he doesn't have one available.
Wanted: Getrag slave arm
You could get one from Bob Parker at www.kickhill.com give him a call.
Dude, just make your own bracket to mount the slave to fit that arm. You just need a flat piece of metal and something to space the slave further back away from the arm because it'll end up too close if you just have it bolted to a flat piece of 1/4" steel. You could just stack another piece of steel where it mounts; then maybe you dont even have to brace it further to keep it from bending. I made a bracket with a drill, sawzall, and welder. Nothing fancy, works great.
You might run into other interference problems if you put the longer arm on there, dont you think?
