Trying to Figure out an MPG Problem
Fastback86
Post by Fastback86 »
Series8217 wrote:The ECM doesn't control the cold start injector, does it? Isn't there a seperate coolant temp switch for the cold start injector?
Yes.
<Insert Sig Here>
p8ntman442
cant get enough of this site!
Post by p8ntman442 »
yup 2 wire sensor near the one wire temp sensor on the upper right of the lower intake manifold.
Blue Shift
Post by Blue Shift »
It's just a bimetal switch, IIRC.
Fastback86
Supposing that the Cold Start Injector is stuck open at least partially, unplugging it would not solve the problem (unless the switch is fubar'd or something), so how would one go about stopping the leaky injector? Just replace it with a new one? Seems easier than trying to rig up some kind of plug for both the LIM and the Fuel Rail.
<Insert Sig Here>
Fastback86
Anybody? Bueller?
<Insert Sig Here>
p8ntman442
pull the injector line from the rail and put in a plug. Leave the injector in the manifold as the lower plug. Both threads are NPT I believe.
Fastback86
Good call. I'll have to see if I can find a plug the right size. Don't really feel like pulling the rail off and taking it to the store with me.
<Insert Sig Here>
lucky
Post by lucky »
pull the line off the rail and the cold start and take that to the store
Fastback86
lucky80 wrote:pull the line off the rail and the cold start and take that to the store
Smart man :thumbleft:
<Insert Sig Here>
lucky
Post by lucky »
thanx. and actually, with the intermediate fitting that's between the line and the rail, you have double the chances of finding something that will work, cause you could either plug the rail or cap the adapter.
