WTB: 4 cylinder intake tube
wanting a 4 cylinder intake tube from a fiero.
This is the flex peice that goes from teh fenderwell to the TBI housing.
Its about 2-3 feet long or so. Everyone should have an idea what it looks like
Give me a price and condition of parts.
I know some of you here haev parts cars laying around. Help a brotha out.
p8ntman442
cant get enough of this site!
Post by p8ntman442 »
i'll check tomorrow if mine is in useable condition, if so just pay shipping.
edit----
these are not gonna be good for air flow unless your cooling brakes with them.
Its for the dual tb intake. its temporary so I can get a filter on this ish.
I however will dyno this to see what happens. They could flow well enough for this turd.
Shaun41178(2) wrote:They could flow well enough for this turd.
Shaun41178(2) wrote:Its for the dual tb intake. its temporary so I can get a filter on this ish.
HUH? I thought you had that thing running... with Nitrous, no less... What's going on?
It is running. I just have never gotten around to hooking up any intake tubing to the tb's.
Basically I have been running around with no filters on for about oh 7 months now or more. Not really sure.
The placement of the tb's with my nothcback decklid makes fitting a aluminum tube very tight and very tight angles. I have test fit many hoses, and mandrel bent tubing. A flex hose would work good. While at home in "Iowa" I was going through some old parts, and I found an old 4 banger intake tube. Don't know how or where I got it but I had it, took a look at it and it appeared to look like it might work by eyeballing it. Brought it back down to Florida and it will work pefectly albeit not the free-est? flowing method.
I can then use the two to make it easier to get a filter hooked up to both tubes, and also to then have a place to mount my nozzles for my second stage of go go juice.
p8ntman442
well, shaun your in luck I have one in good shape, I pulled it from the car Im sending to the junk yard on saturday hopefully. call whatever shipping company you like and schedule a pick up at my house. no charge for the part. its in good condition, your choice of colors, black, black, or black. I will pm my adress and you can arrange the pickup there. dimensions of the box 8x11x15 weight <3 lbs.
Umm.. keep in mind the 84-86 4cyl intake tube is completely different from the 87-88 one...
84-86 has an oval cross section and made of thin material with many pleats... 87-88 is round and made of stiffer material and has a larger cross section...
hmmm I did not know that. I think I have hte later version because this one is round and not oval.
maybe I need an 87-88? I should probably take a pic of what I have.
p8ntman442
post the pic, mine is an 87. I moved back to school, so dont use the address i sent you now. ILL try to make it to the post office after laborday.
sorry it took so long. Almost forgot about this. I still need one.
If you need more pics then I can get them. I would like matching tubes but as long as the lenght and the diameter are the same then I will be happy.
The one here looks round to me. You said one was like oval?
p8ntman442
looks like series saved you some bucks in shipping. thanks man.
Yea thanks series.
I am guessign I have the 87-88 then?
p8ntman442
then from your guessing I can conclude two things. One, you are a bad guesser, and 2 you dont read what I write. Mine is an 87. yours is older. Cant believe it took gm 3 years to make a car specific intake tube, but it did.
Shaun, you can find the older Fiero intake hose you have in any junkyard. Thats the most common one you'll see. Just get your but down there and stuff one in your oversized pants. They wont charge you for it. They may look at you funny.
Why don't you just go to Home Depot and get some PCV pipe with a Y in it? It'll flow better because its smooootth and wont collapse at "high" RPM. I recall Stimpy or someone else with a 3800 telling me about the intake tubing collapsing and choking the motor at WOT. Though I guess with NOS you arent flowing more air then a stock 2.8.. so maybe that doesnt matter.
On the other hand.. blah blah blah blah blah blah...
blah blah blah..
Shaun41178(2) wrote:sorry it took so long. Almost forgot about this. I still need one.
And the one you posted the pic of, I think that is the one I thought was oval. Hmm. Maybe there were 3? 84, 84-86, 87-88? 84 was maybe more like stupid drier hose. The one I was thinking of for the older ones had tighter pleats and was flatenned into an oval / rounded rectangle. Though I could just be tripping. Anyway, the one in your pic isn't the 87-88 one, which is molded to clear the Isuzu shift cables and whatever else (see the flat spots in prototype-bolt-boss-breaker's (:afrocool:) pics? Sorry man too many #s in your name its easier this way.
I need anohter one of these people. HELP
richfiero
Post by richfiero »
get the metal drier tubing its flexible and you can clamp it. its a bit ricey tho
They dont' make it in a small enough diameter. trust me I looked. SMallest is like 3 inches. I need 2 inches.
Kohburn
FierHo
Post by Kohburn »
Shaun41178(2) wrote:They dont' make it in a small enough diameter. trust me I looked. SMallest is like 3 inches. I need 2 inches.
www.mcmaster.com
