v6 blower kit for $1200
The reserve is for 1200. Its for a carb application.
I nkow there are several members out there running carbs. This is a cheap upgrade. Good for 60 ponies.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 8000005680
Unfortunately Kohburn is right.p8ntman442 wrote:your opinion sucks.
Bolting on(If it could be done) the DOHC heads will provide far rgeat power increases than that blower, and your potential of the motor doubles. At the same time, you can keep fuel injection, and go to a DIS.
But, the heads are not exactly a "bolt on mod."
actually i said that for his aluminum motor the blower was a better ideaAaron wrote:Unfortunately Kohburn is right.p8ntman442 wrote:your opinion sucks.
it'd still be able to make more power than the tranny can handle
Re: v6 blower kit for $1200
Hey Shaun,Shaun41178(2) wrote:The reserve is for 1200. Its for a carb application.
I don't have the $$ to blow right now so I'm just curious. I'm running a Holley 390cmf 4bbl carb on my 3.4. Would this blower you're selling work for it.
Sounds like a good upgrade for the crappy 60°V6 motors. Good luck with the sale
Dave
You are afu.
Your ITB setup is easy to get working man. More then enough power making abilities there. Plus you can use them with gen 3 heads too.
I have had the thought of stealing it from you, but it would be doing the same at my house as it is at yours right now. I figure I can use that $ for something else right now.
