fastest fiero?
I dont know why people are so obsessed with top speed. Who cares. You can make a Fiero go 300MPH, but it will probably take 3 hours to get to that speed, and in everyday driving, will be the slowest thing on the road.
To get speed, you need to sacrifice acceleration. I would rather have a car that can accelerate fast than have a high top speed. You win races by out accelerating, not by top speed.
I think my Fiero can out drag any gas powered top speed record holder car in the 1/4 mile. But 4 miles down the road, they might be starting to catch me.
I havent had mine past 175KM/h, I have the formula style front bumper, but I am missisng the lower air dam piece, so my bumper is higher than the underside of my Fiero, I was getting alot of lift and it was wandering bad at that speed even.
If you have two cars with identical engines, the one with the lower top speed will usually accelerate faster. Unless you get more gears to make up the difference.
A salt flats car might have 1000+ HP, but be geared for 250 mph+ top end. The only production based trans that can come close to that is the TH400 (although a 4L85E should probably be able to do it also). Needless to say, low speed acceleration would be lackluster with 2.29 rear and 2.20ish first gear. Of course a 6 or 7 speed Lenco could make up for that...
I still don't think it could be beaten by a Fiero in the 1/4, though.
Top speed course is usually a total of 5 miles: 2 for acceleration, 1 for timing and 2 for deceleration. The course is run in both directions back to back and the times averaged to get the "official" speed.
Been thinkin about that myself. I'm considering removing my cracked sail windows and just smoothing the edges of the hole for looks. I figure the low pressure behind the glass should help pull air in over the deck vents, and possibly lower engine bay temps. Dunno what kind of sound it will make at speed though.....crzyone wrote: Not to mention the great big low pressure area behind the rear glass....
