WTB 94-95 3.4 DOHC Cam Cogs
I need a complete set of the 94-95 style 3.4 DOHC cam cogs with the mounting hardware. PM me.
donk_316
Booooooost
Post by donk_316 »
Whats the diff between them?
91-93
94-95
96
Resident Import Elitist
1991 Skyline GTR
(OO\ SKYLINE /OO)
crzyone
JDM Power FTW
Post by crzyone »
91-93 are hard to adjust, can not loosen the cogs and turn them.
94-95 can be adjusted by loosening the cog I believe
96-97 might not work with the earlier cams?
SappySE107
Post by SappySE107 »
What's the difference between the OBDI belt and OBDII belt?
I ended up finding cogs at the junkyard.
91-93 uses pressed-in lockring to hold cog to camshaft. Cogs have to be removed with a puller to get them to rotate again if you mess up the timing or want to change it. That means removing the belt, resetting the tensioner, etc. They suck.
94-97 use a tapered piece that expands when the bolt is tightened, to lock it against the camshaft.
I dont know what makes 96-97 different from 94-95. Probably # of teeth and so the belt has a different tooth spacing too.. apparently you can swap it over to the old cams though. You have to use the intermediate shaft sprocket too, and of course the different belt.
