'88 rear wheel hub separation?
Posted: Sun Aug 24, 2008 12:08 am
by FGT
I'm trying to separate the rear wheel hub but noticed there is a
nut (29mm?) that seems to go to the axle. I know for the hub removal I need to use a puller tool to separate it but not sure if I need to remove the axle
nut first? :scratch:
Thanks
Posted: Sun Aug 24, 2008 9:32 am
by BC2002SS
yes it will have to come off. good luck getting it off, off of the car like that.
Posted: Sun Aug 24, 2008 10:31 am
On the small pattern (5x100mm) hubs, that's a 30 mm nut. It's tightened to something like 150 ftlbs.
Put a pry-bar through the lug studs and then use a big breaker bar to break the nut loose. It's a self-locking nut, so it'll be stiff most of the way out.
You'll probably have to put the assembly on the floor and push down on the breaker bar to get enough leverage to break it loose.
Posted: Mon Aug 25, 2008 4:26 pm
Do NOT use a puller to seperate the hub. It's is a sealed unit. You need to remove the 3 bolts behind the flange, and remove that large center nut you have highlighted. The entire wheel bearing unit will come off as one piece. There are no serviceable parts inside.
Posted: Mon Aug 25, 2008 4:27 pm
Good catch.
Once the nut's off, just tap the axle out of the bearing with a hammer and unbolt the bearing.
Posted: Tue Aug 26, 2008 1:58 am
by lucky
Does the 88 use a different size nut, IIRC it was a 32mm on my 86.
Posted: Tue Aug 26, 2008 8:24 am
Should be 30 on all 5x100's. Maybe there's an aftermarket bearing that comes with some other size, but all factory's are 30.
Now the 5x115 hubs have 36 mm nuts...
Posted: Tue Aug 26, 2008 1:06 pm
lucky80 wrote:Does the 88 use a different size nut, IIRC it was a 32mm on my 86.
No they all have 30mm. Maybe it was replaced.
Posted: Fri Aug 29, 2008 4:32 pm
by FGT
Thanks guys. I took the part to a mechanic shop I know and with a air impact wrench it came off quickly.
Posted: Fri Aug 29, 2008 4:35 pm
by FGT
Series8217 wrote:Do NOT use a puller to seperate the hub. It's is a sealed unit. You need to remove the 3 bolts behind the flange, and remove that large center nut you have highlighted. The entire wheel bearing unit will come off as one peice. There are no serviceable parts inside.
Thanks... I did read that the hubs on the '88 are different then the previous years and regarding the separation here...
http://fiero.cc/fiero-tdc/members/mws/B ... index.html]
the 88 rear hubs are press-fit together!! This shows the flange portion turned upside down (on the right) with the backing flange bolted to it. The flanges can be taken apart from the hub portion, using a hydraulic press, or careful even pressure, and modified however you want. Then pressed back together after cleaning, re-packing, anything you want!!.
This is a big deal!!
Is this info wrong?
Posted: Wed Sep 03, 2008 2:21 am
FGT wrote:Series8217 wrote:Do NOT use a puller to seperate the hub. It's is a sealed unit. You need to remove the 3 bolts behind the flange, and remove that large center nut you have highlighted. The entire wheel bearing unit will come off as one peice. There are no serviceable parts inside.
The 88 hubs are the same as previous years.
Is this info wrong?
That information is correct. A puller will not take them apart though. You have to use a press.
Why are you taking them apart?
The front race is part of the flange, so you can't do anything to repair it if its damaged.
I suppose you could repack it if you don't trust the factory grease, but its pretty tough to get all the old grease out and replace it with new clean grease.
Are you changing the bolt pattern?
Posted: Wed Sep 03, 2008 8:38 am
Might be able to get a damaged race hard-chromed.
Posted: Sun Sep 14, 2008 12:59 am
by Starlite528
The Dark Side of Will wrote:Might be able to get a damaged race hard-chromed.
A damaged race, what, like the one I used to have?
