Xanth's Interior Build
I've actually already started this on Old Europe, but been spending more time over here as of late and figured I'd update both sites.
Here's what I'm starting with:
Actually in quite nice condition, I want to bring it up to excellent condition and perhaps add a few more modern features while maintaining a stock appearance.
One of the first things I did was the speaker grills:
Prep, I stripped off the old grill material, as well as removed the honeycomb material behind it. With the stock grill there is so much crap between you and the speaker its noticeable how much sound you gain removing that stuff.
In progress, I pulled the surface tight, and pushed down the edge with a razor blade. Then using a soldering iron I gently melted the plastic into the new grill material, doing one side then the opposite side to get the material tight.
And done:
And done:
FieroStore ABS headliner board, uncovered:
Covered the board with 1/4 inch foam:
Applied my new Vinyl:
Trimming for install:
And in the car:
Have to find that darn screw...
1/4 Panel needs cleaning badly:
And for the issues I still have to deal with:
My trim gasket is junk, so I left excess hanging off the top until I get a new one:
Corners don't seal up, due to the mangled gasket:
I've actually fixed the gasket now, just haven't snapped a picture yet.
And in the car:
Okay, a while ago I acquired an old FieroStore carpet off Ebay. The thing that makes it special is it actually has the correct salt and pepper style pattern as stock, unlike the solid colors available now.
First thing, take apart the interior pieces and pull out the old carpet piece:
Now, the common practice with these seems to be to install the new FieroStore carpet directly over the old carpet. The FieroStore carpet does not have the molded foam, only a pad underneath so I can understand why. However, I am not going to get new carpet just to leave my old carpet underneath.
Here is the underside of the original carpet, showing the molded foam:
And here is the molded foam, now liberated from the carpet:
Next step, the insulation, thanks to Lucky80 :thumbleft: :
step, the insulation:
I used my old carpet as a template for cutting out the insulation, then fit and trimmed it in the car.
Fitting in pretty good:
And now the foam pad to smooth everything out. With the pad in place you don't feel any of the floor moldings or ribs:
Hmm.. they show a picture right here:
http://www.jcwhitney.com/autoparts/Sear ... insulation
For the "insulation" category.. but they dont actually have any product like that. :scratch:
Stuff worked great, I'd been putting off buying some for quite some time. Actually been putting off doing the carpet, because I was putting off buying the material :thumbleft:lucky80 wrote:Looking good, glad I could help.
I have to grab one of those, a few people have recommended them to me now. The grime doesn't want to come off with just cleaner, and I don't want to use anything too harsh. Would probably work for if I ever get the headliner dirty as well.Jinxmutt wrote:Magic Eraser will make that B-pillar panel look like new in no time...
Everything is looking great, I need to get a set of those sunvisors!
His visors are excellent, the ones I sent to him were all floppy at the end and just crap overall. These look like new, and I believe they've even improved since then as I have one of the earlier Vinyl versions.
Heres an example of one of his Beechwood ones, done in vinyl:Series8217 wrote:Sweet! Those sunvisors look really good. Maybe I'll get some of those if he has a close match to the Beechwood color.
Where can one get more of that recycled foam insulation with the reflective layer?
http://www.fiero.com/forum/Forum4/HTML/042273-2.html#p79
Kind of odd about the JCWhitney page, it does clearly show exactly what I've got, but its not listed :scratch:
Here's some that looks similar, the rolls are pretty damn expensive but they also list it in sheets:
http://www.sportcompactonly.com/Insulat ... l-2611.htm
You might even find something similar in a home depot, though there may be differences for the automotive stuff.
It's looking really good.
x2 on the letting us know how well the insulation works out.
Fiero Build Thread here:
I'm holding onto my old carpet in the hopes I can somehow remove the vinyl pieces and re-attach them to my new carpet. I took off the one vinyl piece that was on there because it was ugly and just looked very cheap.The Dark Side of Will wrote:I assume you're using the insulation for road noise. Let us know how much of a difference it makes.
I'm kind of annoyed that the Fiero Store carpet doesn't have the "dead pedal" vinyl on the driver's side.
As for the sound difference, its not huge, but definitely noticeable. I don't really hear it in the car being much quieter, however I can hear other noises that I couldn't hear over the road before. Engine sounds a bit louder through the firewall where there is no deadener right now, I can hear the door rods rattle, the intake whistle, and even the fuel pump more clearly now. So the noise from that direction has been reduced, just all the other noises in the car are more noticeable.
And to add, the ABS headliner board does squeak and creak.
Next thing I'm looking into, is some sound dampening for the doors and firewall area.
Anyone familiar with the Vinyl dampening sheets?
http://www.partsexpress.com/webpage.cfm ... roup_ID=37
PartsExpress lists them as being more effective than the asphalt based sheets, plus the reduced weight is always welcome.
They also sell a Hoodliner kit that I may use to redo the firewall in the engine bay.
