I have a few of these sets already made, ready to ship. I am asking 85.00, and that includes USPS priority shipping in the U.S.
Canadian/international shipping PM me.
84-87 Aluminum Cradle mounts
XzotikGT
1987 GT+1996 3.4 dohc+To4b+water injection
Yeah, the problem is that the complete unit is only as strong as that thin wall sleeve. Even though it may appear to be a tight fit, after some time the gap between the sleeve and the Aluminum would begin to increase thereby making a bad situation even worse.
If you design them to replace the sleeve they will be going NOWHERE - friggen NOWHERE, where's this guy going... NOWHERE
But bare in mind your going to have a bunch of retard colapsing the steel together on the subframe when they beat them in with a hammer, instead of properly pressing them in using hardware to keep the subframe steel in place as you press in the aluminum
Well I know what you are talking about with the install part. I ordered a set of the WCF del-alum for the rear control arms. You have to use all the hard ware for those suckers for sure, or you will collapse the arm.
I can make piece to slide into the cotro; arm to make sure you dont screw up the frame too.
XzotikGT
