Question about 60* oil leak
Have you pulled it apart yet? Unless you've actually seen oil on the clutch, you don't know if the slipping clutch is related or coincidental. My oil leak did not cause any clutch slippage, and I can't see how any slow leak would, since it would have to get around to the other side of the flywheel, then down in between the clutch and pressure plate, all while all that shit is spinning at several thousand RPMs.
<Insert Sig Here>
That's a good point, I haven't.Fastback86 wrote:Have you pulled it apart yet? Unless you've actually seen oil on the clutch, you don't know if the slipping clutch is related or coincidental. My oil leak did not cause any clutch slippage, and I can't see how any slow leak would, since it would have to get around to the other side of the flywheel, then down in between the clutch and pressure plate, all while all that shit is spinning at several thousand RPMs.
Furthermore, it is a very minor oil leak. And honest to God, it could be tranny fluid for all I know. It isn't leaking enough to show on either dipstick, and the two look relatively similar at this point (Fresh after change).
Also, I did not do a very traditional clutch break in. According to a Centerforce article I have, the break in is crucial to the performance of the clutch. My break in consisted of a WOT blast through 1st and second to the rev limiter.
No the axle seals are dry.Series8217 wrote:Tranny fluid is a good point. Could your right axle seal be leaking, and flinging into into that area between the bellhousing and the oil pan? That would make it look like its coming from the rear main or the oil pan gasket. I have a leak like that right now.
This is what I'm afraid of, but it could very easily be the case. Weird that it didn't do it with the 2.8l though.FieroGeneral wrote:well, when that happend to me it was my T/o bearing sleeve looking like this:
and the clutch got oily and slippery!
edit: and it leaked just a little oil between the flyweel and the tranny.
yeah..
the t/o bearing sleeve was a PITA to change...i needed to use a 40 ton press to get it out. ( i needed to split the case to get it out. ) the part from the t/o bearing sleeve damaged my presure plate. And it was oil on my flywheel and clutch as well.
i change all the axel seal and checked the getrag at the same time i had it out.
to me it first started as a oil leak between the getrag and the flywheel...and then it started to slip in 5 gear at low rev.
