trans fluid dip stick
Fastback86
Re: trans fluid dip stick
Post by Fastback86 »
There isn't one. The Vehicle Speed Sensor doubles as the dipstick. It's the sensor on the top of the transmission near the trunk. Be very careful when you pull it out or the plastic gear could fall off and you'll never get it back without opening up the transmission case. When you pull the sensor out, you'll see the low and high marks on the side of it.
<Insert Sig Here>
CincinnatiFiero
Post by CincinnatiFiero »
I thought you had a "gertag"
Fastback86
lowlux wrote:what plastic gear?
The one on the bottom of the Vehicle Speed Sensor.
<Insert Sig Here>
