seized motor
Re: seized motor
Does it turn?
Xanth
Re: seized motor
Post by Xanth »
lowlux wrote:no clue.
Well, could you give it a try, perchance?
Re: seized motor
Seized means it won't turn. If you don't know if it will turn or not, then you have no way of knowing if it's seized.
TheFieroBoy
Re: seized motor
Post by TheFieroBoy »
lowlux wrote:how do i check if the motor is seized?
Usually, you would put your car key in the ignition and turn the key. If the starter can turn the engine, then it isn't seized.
If the engine oil looks like chocolate milk, then it needs to be overhauled. If you try to drive it like that, you will destroy the engine.
CincinnatiFiero
Re: seized motor
Post by CincinnatiFiero »
Someone suggested I use PB blaster to free up my locked up CS motor, try that.
lucky
Re: seized motor
Post by lucky »
My friend Bear's ex-wife seized the motor in her escort. Twice a week for a month Bear pulled the plugs, and sprayed in a ton of WD40. It started.
slowpoke
Re: seized motor
Post by slowpoke »
If the government came and took it, it is seized.
slowpoke
Re: seized motor
Post by slowpoke »
If this engine is not in a car, can you guys imagine how many times he has flipped it end over end per your requests. "It turns over fine but fuck its heavy, I need an aluminum block" and then "baby get my vidya camra"
