wtb 88 proportioning valve
looking for one for my 88 formula. thx
Re: wtb 88 proportioning valve
I sent this link to a friend who has one, if he doesn't post soon I'll get at him again.
lmk. I really just need a fitting from it.
Anyone know if the 88 valve is different from the other years?
Shaun41178(2) wrote:lmk. I really just need a fitting from it.
The P-book does list a different part number for the 88 valve.
Are you looking for the port that screws into the front? Dunno if thats the same or not.
thats exactly what I need. That little fitting that screws into the front that feeds the front brakes. I crossthreaded mine when I installed new lines.
If you have a propotioning valve from a non 88 I can take a pic of the fitting from mine to see if I can use it if you want to sell it.
I am on my way to said friends house to do a clutch in his 87GT, I'll snap a pic of the 88 proportioning valve he says he has, stay tuned.
If there's a difference between the two valves, it's probably in the spring inside.
here is mine
take note there is a fitting in the front that I unscrewed where that brake line is supposed to go. That fitting simply unscrews. I need that fitting, or, the whole prop if you don't want to unscrew it.
So you don't need the whole block? There is one on the 88 notchie I found tonight. I am going back tomorrow, let me know if you want it.
please get it. eihter the whole thing, or just that front fitting, whichever is easiest for you. THX!
Isn't the block aluminum? If you cross-threaded the steel fitting enough to screw it up, you probably screwed up the block, also.
Good news for him, I'll be pulling the whole block because I am not wasting 5 minutes of my life for just an insert.
update
Christ woman do I work for you?
Whats it worth to you, he wants money for it lol
$10
I'll box it up tomorrow and hopefully it will only be a couple bucks to ship, it weighs nothing.
