Guys, how reliable is the CC servo on fieros??
Is there a specific failure that happens to all of them?? (weak point)
Thanks,
Cruise control servo??
Re: Cruise control servo??
The servo is pretty reliable. What I've seen happen is the bottom rust out of the tomato can vacuum reservoir.
I've seen that happen a lot too. Take the two 10mm bolts out of it so you can take it out and look all over it. Probably has a hole in it.
