New Whip...M powerrrrr
Re: New Whip...M powerrrrr
Thats the plan. In the process of trying to talk my friends into coming along. I would love to do a few HPDE next year and a few autoX's.
Probably going to try and ditch the fiero come next spring to pay some shit off and get a few things for the M.
Small update...
Did a few exterior things, matte black front kidney grills and fender vents.smoked corner lights, bumper reflector and fender marker light.
Also got some 60 LED angel eyes.
This post is pretty much leading up to a fairly big update.
Massed together a nice array of parts and will hopefully be able to knock it out in 1.5 days (Saturday night and Sunday) to be ready to drive to work on Monday.
The install will most likely be either the 1st or 2nd weekend in March. 1st autoX is the last weekend in March so it should be dialed in by then.
Waiting on one part yet, PowerFlex rear trailing arm bushings. Also need to schedule a subframe inspection before this all goes together... Maybe I'll see if BMWguru can hook me up with a more indepth check than the dealer ship would want to do...
The list:
-TC Kline single adjustable coilovers w/ camber plates- Koni shocks can handle up to 750lb/in spings. I will be running 500lb/in all around. Ride height set to 13.5" center wheel to edge of fender
-PowerFLex RTAB's
-Turner Motorsports (H&R) 30mm front and 25mm rear sway bars, adjustable rear sway bar links
-Vorshlag Poly motor mounts
-Rouge Engineering tranny mounts
-OEM flex disk (inbetween output flange on tranny to driveshaft)
-Hawk HP Plus front pads
-TMS brass caliper sliders
-DOT 4 brake fluid
-eBay headers
The list:
-PowerFLex RTAB's
-DOT 4 brake fluid
-eBay headers
86GT 4sp
teaser:
86GT 4sp
wtf ur ballin. very nice.
I sure feel like a baller haha.
cleaned up a little bit this AM:
Calipers need painted black as well as rotor hats. Windows tinted... not sure if I want the extra hassle of the popo. Car just needs some paint corrections and Ill be happy with the exterior, aside from the CSL trunk:
Then it will be time to save for a BBK and SC.
Guess Ill add a few specs about them
19x8.5 et35- 245/35R19 General UHP
19x9.5 et22- 275/30R19 General UHP
86GT 4sp
Are those VMR 710's? I have the same wheels on my GTI. Same color too. Looking good man!
Don't do the murdered out tint , it will go from looking good , to an italians car.
Otherwise , looks sick..way better then a Pontaic G6 (hammitt is a queer)
Thanks!
VMR V718's actually... 710 lip but the M3 CSL style a little more agressive. The 710s were my first choice but they were out of stock so I went with these.AkursedX wrote:Are those VMR 710's? I have the same wheels on my GTI. Same color too. Looking good man!
86GT 4sp
Nice day today, cleaned and waxed so I hit the casino parking garage for a few shots.
Little sound clip
Little sound clip
86GT 4sp
Car looks good man. I don't think you should black out the windows, but a nice 35% tint all around would look perfect.
Nothing really new with the car, just been driving it.
I did get a StopTech 355mm 4 piston BBK for the fronts, braking is unreal now... and thats on street pads, I have a set of track pads that came with but havent tried them out yet.
Well, I've gone and done it...I bought a supercharger setup.
]For sale is my complete VFE stage 2 kit with all the fixings.
500whp @ only 7,500k, pump
V-box data from verified 8.81 60-130 run on pump.
Worried about another M3 getting the drop on you? Don't be;
Extras;
-Elite Engineering polished aluminum oil catch can
VFE catch oil catch can included as well
Notice the size difference in these two oil catch cans. The catch can that come with the kit form VFE will not fit on earlier models of the M3(2001-2003) because of the placement of the ABS control module. I feel that it looks significantly better as well.
-Snow performance Water Meth injection system
-PLX muti function guage, monitors AFRs, Vacuum, Boost (all essential when running a stage 2 or higher kit)
-Vortech T-trim blower
serial # 49062
model # V-2 1
Custom "VF" front mount
coolant tank
coolant pump
MAF collar/plug, intake tubing, air intake arm, K&N filter w/ protective cover
intake manifold; please note the red water/meth hoses
Manifold gaskets and clamps
Supercharger plate, Belt, belt tensioner and bolts
Upgraded injectors and cooler plugs
Everything needed to make your M3 stinky fast. Boxed and ready for shipment.
86GT 4sp
Oh no, not a supercharger.
That's just....terrible. Yeah.
Is your M3's powerband simply not peaky enough? Get a Vortech!
very nice!
Oh snap!
86GT 4sp
That's one hell of a compact intercooler setup. Looking forward to video.
That's the heat exchanger, A/W FTW!
86GT 4sp
