I bought a Hella TC-400 with my new tires (BF Goodrich G-force T/A KDW). Going to get these installed on my Raze R74 rims sometime this week (hopefully before the next storm comes through).
Anyone else using one of these? Have any recommendations on antenna position, etc? Tire shops in Los Angeles that won't fuck up my rims, and wont look at the pressure sensors the wrong way?
Going to try to do a clean install, but I don't really see any good place to actually integrate it into the dash, so it'll have to be clean as in hidden.
Tire Pressure Monitoring System (TPMS)
Re: Tire Pressure Monitoring System (TPMS)
This thing rules.
I had to file the sending units a bit to get them to clear my hoops. Wasn't a big deal.
I hid the receiver unit on the side of the center tunnel, where the cruise control module goes on the earlier Fieros that didn't have ECM-controlled cruise. I'm running the antenna along the tunnel, tucked under the center console parts. It's picking up the signal very well.
I put the display on the instrument pod above the tach, since there is no instrumentation in that corner. I don't think I'm going to leave it there permanently, because I'd prefer a more integrated solution. I still have to think of a way to integrate it better into the dash..
The system monitors both pressure and temperature for all four tires, has selectable background color, and changes background color to indicate alarm conditions. It also has an audible alarm.
Let's see some pics!
That's a cool little system. (http://www.tirerack.com/accessories/detail.jsp?ID=51)
Did you get a chance to weigh the sensors? I'd be curious to hear what they weigh.
According to Hella the sensors weigh 35 grams.
Here are the full specs: http://www.hella.com/hella-com-en/asset ... PMS_en.pdf
