Steering column shafts
Do any of you know if there were different steering column shafts used in some 88's. I took the front suspension out of the coupe a while back and yesterday while removeing the clutch pedal from my GT I noticed that the GT shaft looks to be much thicker than the one from the coupe. I know that the Formulas and GT had the rear sway bar, could the thicker shaft been for hard turning? I don't know, just thought I would ask.
Re: Steering column shafts
There are 2 different steering shafts for 88. Both are interchangeable. One is for WS6 ( Formula and GT ) and one for without WS6.
The only real difference I see between them is how the lower section mates to the upper. I would guess the non- WS6 one has that encased rubber connector to soften road feedback.
Are you sure it's not just a mid-year change? The front suspension is the same on all 88s, including the rack ratios.. seems weird that they would put a different column shaft in for no reason.
If not, maybe it had something to do with the planned power steering system. The WS6 cars were supposed to get the EHPS rack; the coupes weren't.. hence the differences in alignment settings in some databases.
Series, I'm not certain other than the P-22 lists a 88 W/WS6 and EXEC WS6 steering shaft.
Steering feel from thinner rubber in the telescoping portion?
Just replace all the rubber crap with no-give stuff from Borgeson. That'll improve the feel and response.
I never got to drive the coupe, but I hope to be driving the GT in about another month or so. I was just curious why they would have needed such a thicker shaft, what all did the WS6 package include?
A rear swaybar.
I'm pretty sure the column shaft had something to do with the aborted EHPS. I'm not yet convinced that the factory cars used different shafts for any real reason, assuming your parts are both factory..
