I'm a dunce on audio, I only recently came to understand the sound stage principle. That may not even be the correct term for it. But I'm under the impression that I'd enjoy my music more if I had a 3-way 6x9 speaker on each side of the dash. The left speaker aimed at my left ear, the right speaker aimed at my right ear.
Some cars use a middle speaker.
If I put the speakers near the windshield posts, the sound from the right side has to travel farther to reach my ear, so that might make it sound out of phase. I don't know if I could tell it. Maybe the right speaker should be close to the center of the dash?
I know this isn't as good as tweeters and mids, with a small woofer behind my right elbow, but I have a pair of high quality 3 way 6x9s, and I don't need the woofer. I believe I could build some speaker boxes that wouldn't look horrible sitting on the dash.
Fiero audio
Re: Fiero audio
Couldn't you just adjust the balance a bit more to the right so the right side is a bit louder?
Re: Fiero audio
That's not the same, it doesn't even sound the same. Do an experiment with the speakers you should already have plugged into your PC at home.
Re: Fiero audio
Adjusting the balance is exactly what 95% of the people who are really into audio do though... and if you're not sure if you would notice if the sound is out of phase with speakers in the stock location, then I'm sure you wouldn't notice if you adjusted the balance. Just adjust the balance and fade until it sounds like the music is coming out of the back of your head.
Re: Fiero audio
Works for me.Atilla the Fun wrote:That's not the same, it doesn't even sound the same. Do an experiment with the speakers you should already have plugged into your PC at home.
Re: Fiero audio
you can get an alpine era -g300/320 thats what I did and it will allow you to custom set each speaker so you get what you are looking for. Has a nice display with a hideaway brain box. You can get them for about 300 on ebay. It works great and very easy to work with.
Re: Fiero audio
You *can* build an adapter plate/block to mount 6x9's in the stock locations from below the dash.
Rather than the sound from the speakers being "out of phase", you may hear "smearing" of the high frequencies due to reflections off the windshield. Generally right below the windshield is a lousy place for tweeters.
