Craigslist find: SD4 convertible
Re: Craigslist find: SD4 convertible
cool find. not sure it's worth half what the guys asking but still cool
out of curiousity, how did you stumble upon that?
Fastback86
Post by Fastback86 »
Ah yes, the elusive 1994 model. Very hard to find. I think we can safely assume this guy didn't build the car himself.
<Insert Sig Here>
It was on Pfiffle.
Maybe Indy can chime in, but I was under the impression that it would be hard to put together an SD4 longblock for $7K, much less a whole running engine.
crzyone
JDM Power FTW
Post by crzyone »
The SD is cool and all but there isn't anything it can do that a off the shelf parts ecotec couldn't do while being lighter and having a much broader powerband.
It's neat but not worth the money.
Indy
Post by Indy »
You could probably do a long block for <5K if you didn't want anything nice...Use SBC valves, pistons, rods, BBC rocker arms. Score an old Pontiac SD crank from somewhere. When I still had the Diamond pistons my shortblock with cam totaled a little under $3000. Used-ish crank, new block. After the custom CP's, I didn't bother with keeping track...
Looks like it has injected ITB's...Probably means good things for what's inside.
