84 ignition module help please thanks
in the second pic of the ignition module what pins are for the pick up coil 123456? aslo in the second pic. how do you get this pressed fit nut off the shaft so i can replace the pick up coil? is there a tool to pull it off like a steering wheel puller? and does the wires look correct as in the places where there connected to? thanks
- shaft bolt.jpg (47.11 KiB) Viewed 1079 times
- ig mod.jpg (27.88 KiB) Viewed 1079 times
