I woke up to this idea
Atilla the Fun
Re: I woke up to this idea
Post by Atilla the Fun »
befarrer wrote:I wonder why all the big diesel engines and heavy trucks use Inline 6 motors, I cant think of any new diesel motor that is in the heavy truck or heavy industry category that is a V configuration.
Doesn't bore and stroke have something to do about torque as well, if you think about it, a longer stroke engine has more leverage on the crankshaft (connecting rod center is further away from the center of the crank), sure the piston has to move further, but it takes less force to make the same flywheel torque, but since the piston has to move further, it cant rev as high as say, a larger bore, shorter stroke motor.
Heavy apps are all about profit, not fun. D-Max is a fun diesel, not a profit diesel like the Cummins. The Cummins is for work, the D-Max is for play. I'm here to play. If I wanted to profit from a diesel, I'd drive a big rig for a living.
Atilla the Fun
Here's the perfect app for a 2JZ or RB26DETT, or even a 6BT, on the salt:
Inline 6's are smoother than V6's. It may not seem like much, but over hundreds of thousands of miles a year, it adds up. Even if it only matters in driver fatigue.
It's easier to plumb the turbos on an I6, also.
Blue Shift
Post by Blue Shift »
BEST SWAP EVAAAARRRRR!!!11!1one11!!: http://www.youtube.com/watch?v=sAWbD9io6bg
Atilla the Fun
http://www.youtube.com/watch?v=Lw9FTFlSsB0&feature=fvw might be better
need to add that song that goes: "....somebody call nine one one, little shorty fire burning..."
Atilla the Fun wrote:Here's the perfect app for a 2JZ or RB26DETT, or even a 6BT, on the salt:
I might do an engine swap on a 308, but not one of those (I guessed a 250 Barchetta and then looked at the file name...). The car has a 2 litre V12 stock. It would collapse if you tried to put a 6BT in it. It would bend the control arms before you could put enough spring in it to keep it off the bump stops.
Atilla the Fun
Well since the originals are in the millions of dollars, to do one for the salt would be a fiberglass phony on a tube frame. But it is narrow, with less frontal area than a Miata. It should be possible to get a V6-90 in there, but why try?
pontiackid86
Post by pontiackid86 »
crzyone wrote:
pontiackid86 wrote:
crzyone wrote:Pontifag gets under my skin, my posts were not directed to anyone other than him.
Good to know im doing a good job. Hows that beaner failure you call a skyline. You figure out weather its an R32 or an R34 yet?
. You are literally one of the dumbest people I've seen on these forums.
This comming from the RERE who does half an R34 conversion on an R32
Atilla the Fun
kid, noone invited you to my party. Please leave. And stay away. Forever. Thank you kindly.
Fastback86
Post by Fastback86 »
This coming from a guy who actually uses the term "rere."
<Insert Sig Here>
CincinnatiFiero
Post by CincinnatiFiero »
Atilla the Fun
I'm unable to find words suitable for my reaction.
crzyone
JDM Power FTW
Post by crzyone »
WTF is a rere? Do you speak english?
pontiackid86
It means You are a retard dumbass.. bone up on your insults you are on RFT after all.
CincinnatiFiero
Rick, what do you know about the V8 versus diesel debate? Thoughts?
crzyone
JDM Power FTW
Post by crzyone »
pontiackid86 wrote: It means You are a retard dumbass.. bone up on your insults you are on RFT after all.
The unemployed broke ass bitch calling me a retard. That's rich. :lol:
pontiackid86
Again comming from the idiot who rices out a skyline.
coinage
Post by coinage »
Since when is adding a functional wing to a stripped out, caged,400+whp *RACE CAR* ,rice??
86GT 4sp
Atilla the Fun
I asked nicely, stay the hell out of my thread. In fact, do us all a favor and leave CrazyOne alone, and stay the hell out of RFT, forever.
CincinnatiFiero
Mercedes Diesel running 10.6, not too shabby. Hes running the 3.0L DOHC, I've got a 3.0L SOHC but I'd be lying if I didn't tell you I've got a 3.0L DOHC motor sitting in the back of the warehouse
http://www.youtube.com/watch?v=DUppvE8zSdM
