86se v6 part out
86se v6 part out
parting off the 86 se turbo car. I need to make room for other projects.
Has corvette brakes I think, kris munson headlights aftermarket rims yadda yadda. If you need body panels or anything interior like carpet let me know. I would hate to scrap the car with all this cool aftermarket stuff on it, but I will if noone wants it.
it has a dohc 3.4 in it so if you need cheep engine parts lmk and I will pull them off. Also has a wraparound wing.
any engine parts you want or brackets let me know. maybe you are doing, will be doing, or know someone wanting to do a dohc swap.
http://www.shaun.saturnet.net/pics/dohc/100_1421.JPG
poly bushings with grease fittings throughout suspension
http://img.photobucket.com/albums/v435/ ... m_0461.jpg
poly engine/trans mounts
http://img.photobucket.com/albums/v435/ ... m_0450.jpg
http://img.photobucket.com/albums/v435/ ... m_0449.jpg
http://img.photobucket.com/albums/v435/ ... m_0492.jpg
gas lift for decklid
http://img.photobucket.com/albums/v435/ ... m_0437.jpg
front battery (battery hold down redesigned since this picture)
http://img.photobucket.com/albums/v435/ ... attery.jpg
11.25" brake upgrade
http://img.photobucket.com/albums/v435/ ... m_0379.jpg
17x8 tenzo rims with 225 yoko tires
http://img.photobucket.com/albums/v435/ ... o-rims.jpg
-adjustable fuel pressure regulator with gauge
-3800sc 36# injectors
-fuel rail converted to returnless
-wideband O2 from innovate
-revo boost, O2, oil pressure gauges
-195* fan switch
-fan override switch
-10" cooling fan on top of intercooler wired into fan system.
-kmunson recessed headlight clear covers and buckets with 6 driving lights inside, 4x 50watt low beam, 2x 100watt high beam.. have stock buckets to put back in if desired
-decklid weatherstrip to block water from front plugs
-turboxs BOV
-moates APU autoprom unit for tuning 89 TGP ECU
-short shifter
-3.65 4speed
-stage 2 spec clutch
-sunroof
-working e-brake
-195* fan switch
-turboxs BOV
-short shifter
-3.65 4speed
-sunroof
-working e-brake
Re: 86se v6 part out
how much for the brake upgrade?
I looked on archies site and its $1440 for the kit. Make an offer
LOL.
You and I both know $1,440 is one of archies delusions and I'm amazed you tried to use it as a place to start over here. I'd try that on .nl. I'd tell you what I spent with Will and on all brand new shit at Pep Boys but I don't want to ruin your chances at $1,000.
I wasn't thinking anywhere near $1k. quite the opposite actually
I used his site because other sites I looked at didn't have everything as a kit. I would mostly see the brackets and people would have to piece the rest togethor themselves. I saw the parts needed, but I wasn't going to price each out individually. if you want to post your pep boy prices for it all be my guest. the more info the better. Madman can make an offer based off that, and I will get a more accurate idea of what its actually worth.
or if you can find another vendor selling everything as a kit, and its cheaper then 1400 post that up too.
This is from the fiero addiction website
just found this more info on it.
phpBB/viewtopic.php?f=3&t=1074&start=0
Price it out, make an offer. I also have a larger master cylinder too I think from a blazer or whatever is used with this upgrade.Requires four rear rotors, 91-95 Acclaim; 89-93 Daytona; 89-95 LeBaron; 1994 Shadow; 91-95 Spirit
Requires two front calipers, 95-97 Blazer; 82-86 Bonneville; 78-88 Caballero; 78-84 Calais; 82-92 Camaro,Berlinetta,Iroc,Z28; 78-81 Century; 78-88 Cutlass Supreme, 442; 78-88 El Camino; 82-92 Firebird, Trans Am; 78-80 Grand Am; 78-87 Grand Prix; 96-97 Isuzu Trk. Hombre; 95-97 Jimmy/Yukon; 78-83 LeMans; 87-95 LLV Postal Vehicle; 78-83 Malibu; 78-88 Monte Carlo; 1978 Oldsmobile Vista Cruiser; 78-87 Regal; 82-97 S & T10 Blazer; 82-99 S & T10 Pickup; 82-97 S & T15 Jimmy; 82-99 S & T15 Sonoma
Or two front calipers, 95-97 Blazer; 79-85 Eldorado; 95-97 Jimmy/Yukon; 91-96 Oldsmobile Bravada; 79-85 Riviera; 82-97 S & T10 Blazer; 82-97 S & T10 Pickup; 82-97 S & T15 Jimmy; 82-97 S & T15 Sonoma; 80-85 Seville; 79-85 Toronado/Trofeo
Requires two rear calipers, 79-85 Eldorado; 79-85 Riviera; 80-85 Seville; 79-85 Toronado/Trofeo
FWIW the last LeBaron swap I did was right around 600.00 Canadian for new brake parts ( Reman calipers and MC). That was not including the brackets.
Calipers - $11.99 ea. (Blazer) - Pep Boys
Rotors - $21.99 ea. (LeBaron) - Auto Parts Nerd
Hawk Pads - $18.99 axle (clearance) - Pep Boys
Hubs - $70 - Machine Shop
Adaptors - $200 (I didn't pay full price but that is what I recall Will charges) - Will
Stainless Brake Lines - $99 - eBay
C3 Master Cylinder - $20 - Pep Boys
~$530 so about inline with ~$600 cdn.
Im just not going to make an offer, I would like the brake upgrade but I can't afford what you probably think they are worth.
http://img16.imageshack.us/i/img00311201005291822.jpg/
http://img19.imageshack.us/i/img00312201005291822.jpg/
http://img517.imageshack.us/i/img00313201005291822.jpg/
http://img17.imageshack.us/i/img00308201005291821.jpg/
http://img375.imageshack.us/i/img00309201005291821.jpg/
Kris Munson headlights, Kris munson front turn signal covers, 3 face gauge pod.
