3.4PR 9 11/16 clutch/pressure plate in a 3.65 4 speed
coinage
Post by coinage »
It works, no modifications needed. I am currently using this on my DOHC turbo setup and seems to be doing ok at the moment, but I havent turned up the boost yet... or put much mileage on it yet.
I am using a ClutchNet "Red" 6 puck unsprung hub and a "Green" pressure plate.
Not sure if it works on anything else as the fingers on the PP stick out pretty far, in the 4 speed case I had maybe an 1/8" clearance between the TOB and the fingers on the PP.
86GT 4sp
