Cadillac on the Salt
http://www.autoblog.com/2009/10/12/vide ... ecord-for/
1800+ HP on *gasoline* on a production 2 BOLT block and production CAST crankshaft with ported production cylinder heads.
2JZ what?
Re: Cadillac on the Salt
How and where do you tune something like that?
Atilla the Fun
Post by Atilla the Fun »
"a custom Cadillac V8 measuring 529 cubic inches (8.8 liters) in capacity, boosted by a pair of intercooled 88mm turbochargers, custom forged rods, solid roller cam, ported heads and oversized valves"
529 means stroker, and even if they offset-ground the original crank, that's still not a "stock" crank.
And considering what they were doing, they should have been de-stroking a 472.
It's not a *stock* crank, but it is a *production* crank. It's probably been nitrided and had a few other interesting things done to it as well.
It's offset ground *DOWN* to BBC journal size.
I think 1800 HP on a production cast crank is damned impressive.
Fastback86
Post by Fastback86 »
<Insert Sig Here>
Atilla the Fun wrote:"a custom Cadillac V8 measuring 529 cubic inches (8.8 liters) in capacity, boosted by a pair of intercooled 88mm turbochargers, custom forged rods, solid roller cam, ported heads and oversized valves"
472 and 500 have the same bore. Absent regulations limiting displacement, bigger is better.
Also, the big block Caddy architecture has 4 head bolts per cylinder. Stock they are 1/2" bolts tightened to 105 ftlbs. I don't even want to know what size/torque the Spectre engine uses.
Fastback's link was very entertaining!
"Word is that the intercooler is so efficient that air enters the intake plenum at a frosty 39 degrees Fahrenheit."
That's fucking amazing. I want.
Did you see how big it is? It's as large as the block.
It's basically an ice chest with air passages through it.
Didn't have a better place to put this:
http://www.hotrod.com/techarticles/engi ... ewall.html
