What spark plug gap are you guys running for 8psi on a 2.8 turbo? My engine it's cutting off past 5k rpm and I think it's the plugs.
ECM has been chiped for 2bar map by Sinister, has MSD 6a box and MSD coil, cap and rotor and Magnecor wires. New module, new pickup, stock timing. Running 1 range colder Autolite plugs (number 23) @ .34
The engine was tuned on a dyno with BEGI FMU and Apexi but haven't been able to go past 5k ish
It feels as and ECM cut off but it isn't cuz it's kinda gradual. It's making full boost @ 3500 and keeps on going hard until it reaches 5K and starts to feel slower then around 5200 to 5300 rpms it cuts off.
Turbo Spark plug gap
Re: Turbo Spark plug gap
That gap seems a little high. I think I was running around .025-.028 on mine. i would have to pull my plug gap gauge to know for sure though. I do know I had to come down quite a bit from stock even with my aftermarket ignition.
What does your dyno graph look like when the spark cuts out?
BEWARE OF BEN PHELPS. YOU HAVE BEEN WARNED. WORSE THAN MILZY IMO
Put the gap down to .025 and see what happens. If it still cuts out at 5200 then I am pretty sure I know what your problem is. I was having a similar problem when I first got my setup running. keep me updated
