Atilla: you should go pick these up
Re: Atilla: you should go pick these up
They'd look good on the Fiero
Damn it will, everytime I get linked to those auction sites I end up looking at 2.5 ton 6x6s all evening and think its a potential substitute for a Cummins Ram. I use a truck every other month so fuel economy and practicality are null, but I do need an unstoppable winter rig, and I like being different... The 6x6 has all of that The question is what is the fuel economy, can the non turbo diesels get to 10mpg? I went and looked at two unimogs but the "fast axles" topping out at 60mph made it quite impractical. The 6x6 isn't much faster but they don't bounce off the limiter on the highway and are diesel, I could only afford a 404 mog.
Gun tubes! Richard Hammond would agree with you. Supercars should have guns. But those might be a bit much for a Fiero. Now, if you can find something a bit more, I dunno, James Bond style, for around $150 each, delivered, with ammo, then I'm in for 4 of them.
Lol... If you want to play, you gotta pay.
Can barely get a paintball gun for less than $150.
I'm torn. Should I answer: "exactly" or should I answer "perfect" or should I answer "I'm okay with used guns" ?
I've shot skeet, but guns just don't have any place in my life. As an image thing on a car, maybe. But you can bet I'd fill the barrel full of weld.
A Mossin Naggant cost $100 new.The Dark Side of Will wrote: Can barely get a paintball gun for less than $150.
16" Mark 7 are Iowa Class guns. Would be fucking sweet to get 9 of these and mount them in the back yard in the proper configuration pointed about 30 degrees skyward.
Shipping to Nova Scotia would be a bitch though.....
