Page 1 of 2
FS: 2 N* Engines, F40 Trans, MEFI 4B ECM & 88 Cradle Setup
Posted: Thu Feb 02, 2012 4:12 pm
by mcaanda
New thread listed.
Re: FS: 2 N* Engines, F40 Trans, MEFI 4B ECM & 88 Cradle Set
Posted: Thu Feb 02, 2012 6:29 pm
by crzyone
Wow, good deal.
If I had that ecu instead of the POS bigstuff 3 I would still have my car. Frustrating with it never quite running correctly. Nobody else had a 2000+ N* at the time, and breaking new ground wasn't what I should have been doing.
This makes me want to sell a car and get an 88GT to put this in
Posted: Fri Feb 03, 2012 1:42 am
by mcaanda
crzyone wrote:Wow, good deal.
For the right $$ I'd let this go w/ it.
20K original mile 88GT:
Posted: Fri Feb 03, 2012 4:25 am
Looks interesting. I'll be going to a 6 speed eventually, so you snagged my attention with the F40; the pre-modified '88 cradle looks tempting too, as does the MEFI...
But I have zero need for more engines...
Posted: Fri Feb 03, 2012 12:59 pm
by crzyone
mcaanda wrote:crzyone wrote:Wow, good deal.
You are killing me. You should list a package price.
Posted: Sat Feb 04, 2012 1:49 am
by mcaanda
crzyone wrote:mcaanda wrote:crzyone wrote:Wow, good deal.
Yea, the only thing is that the $$ of what I'd want for the GT is going to be enough that most if not all people would say I was nuts. I really happened to fall into the car by happenstance and TBH 20K mile GT's are getting kinda hard to find and when you do they want damn near a mint for 'em. TBH, I think that I'd fall into that camp as well.
Posted: Sat Feb 04, 2012 8:48 pm
20k and someone butchered the 1/4 windows?
Posted: Sun Feb 05, 2012 12:18 am
by mcaanda
Aaron wrote:20k and someone butchere
d the 1/4 windows?
Yup, was that way when I bought it.
Posted: Sun Mar 11, 2012 10:31 am
by mcaanda
Updated asking.
Posted: Sun Mar 11, 2012 3:33 pm
by crzyone
If you can't sell at that price, fiero owners have not changed one bit.
If I didn't already have 2 cars...
Posted: Wed Mar 14, 2012 10:06 am
Posted: Wed Mar 14, 2012 10:23 am
by eHoward
So what would one need to complete an install?
Fiero
The various 88 rear suspension bits
Exhaust/intake
Clutch/pressure plate
Shifter cables
Anything else?
Posted: Wed Mar 14, 2012 10:30 am
by mcaanda
Very cool site - I just .pdf'd the link. If this thing does not sell, I'll have to put the info to good use.
eHoward wrote:So what would one need to complete an install?
Fiero
Exhaust/intake
Shifter cables
Anything else?
If you had an 88 Fiero already, I'd say exhaust, axles, clutch ( the flywheels included; see pics above or click
[here] ) Electric H20 pump, as this was the plan that I was going to due hence the machined AN fittings on the block.
Standard fuel lines, water lines, ect... and its installed. Just that easy...
Posted: Wed Mar 14, 2012 10:37 am
by eHoward
So they cobalt axles aren't bolt-in?
What do you do for axles on a F40?
Posted: Wed Mar 14, 2012 10:54 am
by mcaanda
eHoward wrote:So they cobalt axles aren't bolt-in?
I have the axles for the SS Cobalt yes, they are not drop in for the Fiero tho. I was going to use the input shaft side into the G6 trans, and then fab the other half that goes into the Fiero hub.
Posted: Wed Mar 14, 2012 7:44 pm
It's probably easiest to just order some axles from the
Driveshaft Shop after you mount the drivetrain and get some measurements.
Posted: Wed Mar 14, 2012 11:50 pm
by mcaanda
Series8217 wrote:It's probably easiest to just order some axles from the
That was a thought also.
Posted: Sat Mar 17, 2012 3:45 am
by mcaanda
Damn, you'd think that I couldn't give this shit away. WTH?
Not even an E-mail asking about it. Is the N* market just that non-desirable? Am I asking too much?
Posted: Sat Mar 17, 2012 7:51 am
by Emc209i
mcaanda wrote:Is the N* market just that non-desirable?
Yeah.. I know I wouldn't touch one. Do you wanna use the time machine, its free at lunch?
Posted: Sat Mar 17, 2012 9:21 am
If I were just getting started on a Northstar swap, I'd be all over this.
No doubt you have a lot of outstanding hardware at a fantastic price... just hold out for the right buyer.
