need one to help swap cradles and also construct a dog bone mount down to the frame.
If anyone has one let me know..
WTB: LQ1 Front engine lift / dogbone strut bracket
Re: WTB: LQ1 Front engine lift / dogbone strut bracket
That's the one that sandwiches between the timing cover and the head, next to the power steering pump?
Negative, the other one on the rear of the block that sits close to the fiero firewall or the "stock" dogbone mount / engine lift in the W-bodies. My LQ1 doesn't have one and could use it to 1.) lift the block off the cradle while I swap in an 88 and 2.) I came across a dogbone mount on OE that goes from that lift/dogbone mount straight down to the frame to the right of the where the fuel fill cut into the frame.Series8217 wrote:That's the one that sandwiches between the timing cover and the head, next to the power steering pump?
Late reply, but I have one. It's brand new, came off a GM crate engine. Make an offer, but keep in mind it's heavy so shipping will cost ya. I'll get a pick if you need me to.
Sorry, just saw this reply, I picked one up from local speed shop Engineered.netAaron wrote:Late reply, but I have one. It's brand new, came off a GM crate engine. Make an offer, but keep in mind it's heavy so shipping will cost ya. I'll get a pick if you need me to.
