Page 19 of 63
Posted: Wed Jul 12, 2017 5:06 pm
all of my fancy tube flares in the fuel system held pressure as prescribed, so the fuel system is buttoned back up. I'm working on getting vacuum and boost lines made up, I had to make a few new fittings, my local source said that a tee fitting with -6 on the straights and -4 on the leg didn't exist, so I bought a -6 tee, cut the leg off and TIG'd on a -4. I need a couple more oddball fittings, but I know though exist, so hopefully I can pick them up tomorrow.
the list:
brake booster line
wastedgate and boost controller lines
BOV lines
fuel pressure regulator reference line
intercooler mount/plumbing
induction piping
pull up resistors for the MS3x (if required)
starter wiring
bulkhead passthrough for the harness
tune.
Here's a picture of how I left it the other day. the tube going around the MAP sensor is the brake booster line I started making, it's also where I've tee'd off the boost sense line for the wastegate, you can see the solenoid mounted under the front right intake bolt.
- work.jpg (103.42 KiB) Viewed 1927 times
Posted: Sun Jul 30, 2017 5:33 am
looking st the list, it looks like I haven't got shit done, but I have been working on the car quite a bit. I decided the old intercooler was going to be too much of a PITA to make work with the new engine mounts and subframe, so I picked up a new one that I think I should be able to make work, might take a little welding though. I welded up a new downpipe, all that's left with that is to install a flex coupling in it to ensure it doesn't crack. hopefully I get off work at a reasonable hour tomorrow morning, and can get to work on the intercooler mods, as well as the charge piping.
the list:
induction piping
tune.
Posted: Sun Jul 30, 2017 7:13 am
So you're basically redoing your whole setup.
You fired it with the ms3 yet?
Posted: Thu Aug 03, 2017 3:36 pm
Shaun41178(2) wrote:So you're basically redoing your whole setup.
yes and no. the boost piping and intercooler arrangement, yes, the exhaust, just the downpipe. I welded up a new outlet a new intercooler, and tomorrow, I'm going to try and do the inlet. the new intercooler will be mounted between the engine and the right rear frame rail.
I haven't fired it yet on the MS3, but I have pretty much finished the MS3 setup and configuration. I'm going to try and knock out a crank and cam sensor learn sometime this week depending on how things go together.
Posted: Tue Aug 15, 2017 4:27 pm
Among other things, the intercooler is mounted, it's in a much better place. FYI, welding aluminum is very difficult the outlet of the intercooler is now 3" instead of 2.5", eliminating the need for an adapter to the maf, the outlet was turned 90 degrees as well to promote better fitment.
- cool.jpg (93.25 KiB) Viewed 1882 times
Posted: Wed Aug 16, 2017 3:34 pm
the charge piping is all done, ugly as hell, (I really suck at welding aluminum...) but I was able to eliminate several clamped connections, and silicone adapters. makes it a bit more difficult to install, but not excessively so. I'm going to finish installing it and the intercooler tomorrow, try and bleed the clutch, and commence Verification/diagnostics on the megasquirt install and settings.
- ugly.jpg (138.81 KiB) Viewed 1877 times
Posted: Thu Aug 17, 2017 4:03 pm
I installed loom on the harness and got everything more or less finished up wiring wise in the engine compartment, tomorrow, I'm going to get the intercooler plumbed, and try to get the interior wiring buttoned up. once that's done, I'm going to try and turn the engine over to determine if I need to install "pull up resistors" on the crank and cam sensor signals, and then I'll pull the MS3 back out to install the pull up for the MAF, (and crank/cam if needed) hopefully things go smooth, but I'm not holding my breath.
the list:
intercooler plumbing
tune.
Posted: Thu Aug 17, 2017 7:13 pm
Great to see you're getting really close on this.
Especially since you started the thread in 2013
Posted: Fri Aug 18, 2017 1:22 pm
The Dark Side of Will wrote:Great to see you're getting really close on this.
yeah, maybe I should have called it "3500 rebuild, ejs262 style"...
So far, i've only knocked one thing off the list today, and that's the intercooler plumbing, but I did put the battery back in, and I haven't noticed any funny burning smells yet. I do have some oddities I need to track down, while cranking, I'm not getting a cam signal, only crank in the logger, on the dashboard, it doesn't show a cam sensor fault though, or a sync fault. I'm going to have to probe some minds to see whats up. could be that I need a pull up resistor for just the cam signal, or the brand new cam sensor I installed is bad.
Posted: Sat Aug 19, 2017 10:50 am
cam position sensor is "fixed"... helps alot to plug the thing in... LOL
Posted: Sun Aug 20, 2017 6:23 am
Just be glad it was easy.
Posted: Mon Aug 21, 2017 5:22 am
Me too, I've started testing and am getting pretty close to attempting to start this old girl up, it's an odd feeling, both terror, and excitement. lots of second checking and what if thoughts...
I've found a couple of small issues so far, but nothing that appears catastrophic.
this is what the MS3 sees for the crank and cam sensor.
- compllog.png (29.49 KiB) Viewed 1847 times
here is a short video of something that surprised me. injectors are pretty loud, this is all 6 firing I don't remember what RPM was being simulated though...
https://youtu.be/UywWUo5cwe8
here is coil #1 being tested. so far, everything is looking ok.
https://youtu.be/N4IeRIal2ow
Posted: Tue Aug 22, 2017 6:22 am
You're doing a lot more subsystem testing than most people do.
Posted: Tue Aug 22, 2017 9:54 am
The Dark Side of Will wrote:You're doing a lot more subsystem testing than most people do.
They are functions available within the controller, it would be a shame to not use them. it also allows me to verify that all of my wiring is true, and functions as prescribed.
Posted: Fri Sep 15, 2017 9:03 am
Making boooooost?
Posted: Fri Sep 15, 2017 6:44 pm
Did you avoid Harvey AND Irma?
Posted: Mon Sep 18, 2017 5:47 pm
short update, the car is in Pensacola, both the car and I avoided both hurricanes, unfortunately, I ran into the time thing again, and will be away from the car for about a year if things go according to schedule, although, I'm not at liberty to discuss the details of that schedule... pearl harbor was going to be a bit of a PITA with not nearly enough time or space to work on it, so storage was the best option. hopefully when I get back on the mainland, I can get rolling right back into it.
Posted: Mon Sep 18, 2017 6:24 pm
Going to pearl for a year?
Individual Augmentee?
Posted: Tue Sep 19, 2017 7:10 pm
The Dark Side of Will wrote:Going to pearl for a year?
Change of homeport, I'm attached to the USS Bremerton(SSN-698), the oldest active boat in the fleet... IA... LOL Nukes need not apply for anything cool or unusual.
Posted: Fri Apr 13, 2018 11:06 pm
Back from deployment, one underway left and then hopefully I can get back to work on this, and many other projects...
