Getting started: tuning and coding obd2
Do any of you guys know of any good reading/info on how to manipulate obd2 PCM data and coding? I'm working on my 3500 swap Fiero, and I see all kinds of unused inputs and outputs on the PCM connectors that could be put to use, but the current programming doesn't allow it, so I'd like to learn how to make use of them.
Re: Getting started: tuning and coding obd2
Start by identifying the primary microcontroller on the ECU, then obtain and read its datasheet.
How good are you with assembly code?
right now... well I intend to learn how, at this point though, I don't really know where to start.
You need to find a disassembler that works with the instruction set of the chip (primary microcontroller) and disassemble the .bin file
This is done in passes, as different branches within the program will touch different instructions and different locations in the file.
For OBDI, the first two locations in memory are the PROM ID.
You look through the program for an instruction that references that location. The only time the program uses its own ID is when it's outputting that ID to the data stream. Thus the only part of the program that references that location is the data stream output module. You can then use the sequence of data outputs to find the locations of the variables that represent the PID's in the datastream.
It's a big pain in the ass and requires you to be determined, unflagging and highly "retentive".
found a disassembler:
https://www.hex-rays.com/products/ida/s ... ware.shtml
appears to work fine, but I'm still learning what all is going on in there...
Edit: works, but can't handle as many processors as our PCM's use...
this appears to be a good read on the subject:
http://www.thirdgen.org/techboard/diy-p ... -step.html
well, here's a year later bump...
I got a legit disassembler that can handle the file, along with a manual on the 68332 processor. i'm gonna start playing with this a little more when I have time. if anyone has suggestions, I'm all ears.
Start with the address of the PROM ID or whatever the ID byte is in an OBDII .bin, find the instruction that references that address, use that to find the PID output module and go from there.
so, I've been playing around in IDA and winOLS, and it's interesting to see that the code is VERY similar between the 3x00, the 3800, and the LX5.
to put numbers out there, according to winOLS, the LX5 bin is 81% identical to the 3400 LA1 bin. I would imagine the 19% difference could be made up in just all of the calibration tables. There's still quite a bit to be uncovered, but I'm starting to think some of the things I wanted to accomplish, like true coil per cylinder, may be easier then I thought.
interestingly enough, just setting the auto transmission parameters to 0, along with removing torque management on the transmission side of the LX5 bin, resulted in the bin registering 87% similar. I think it's a far assumption that if the calibration parameters were the same, each of the above mentioned bins would be very close to identical. just looking at the code, they all appear to be extremely similar.
I figured this might be helpful for me, so it might be helpful for others too, parameter addresses for the short* bin osid 12586835 all addresses are according to tiny tuners database. I think some might be wrong though, still looking into it.
1c970-ect temp vs votage
6f1d8-ignore flash checksum
6f1d9-disable flash security
6f1da-module programmed
6f1dc-engine type
6f1dd-crank resolution
6f1de-supercharger present
6f1e8-a/c RPM disable
6f1f4-a/c on startup delay
6f208-a/c min air temp
6f20a-a/c disable/re-enable ECT
6f20e-a/c disable/re-enable tps
6f212-a/c disable timer
6f22a-a/c disable/re-enable ignition voltage
6f234-MAF airflow table
6f2d6-MAF max positive airflow change
6f2fc-MAF negative airflow change
6f398-transient airmass calc mode
6f39a-max cylinder air mass
6f3a0-transient airmass calce enable positive tps delta
6f3a2-transient airmass calc enable negative tps delta
6f3aa-default mass airflow (GM/sec) vs TPS vs RPM
6f674-MAF failure airmass calc mode
6f68a-speed density maf compensation vs ect
6f69e-speed density maf compensation vs baro
6f736-volumetric efficiency
6f934-ve correction vs tps vs egr state
6f94c-speed density maf compensation vs IAT
6fae0-air pump system present
6faf6-air pump enable startup coolant temp
6fb2c-alternator startup delay vs ECT
6fb40-alternator RPM cutout
6fbea-default baro
6fbec-always use default baro
6fbf0-SC baro lookup
6fc32-NA baro lookup vs tps vs rpm
6fe4e-o2 sensor config for pid 13
6fe50-boost delay-boost timer base
6fe66-boost delay-timer adder tcs on
6feaa-boost delay-timer adder tcs off
6fefe-CCP enable coolant temp
70060-ect ok enable ert
70062-ect ok enable ect
70064-ect ok disable ect
70066-ect ok enable ect dtc set
70068-ect ok disable ect dtc set
7006a-ect temp vs ert
702d6-knock sensor diagnostic min ect
702d8-knock sensor diagnostic min engine load
702da-knock sensor diagnostic rpm thresholds
702e8-knock sensor diagnostic min ert
702ec-knock sensor circuit diagnostic min fails per sample to set DTC
702ee-knock sensor circuit diagnostic test sample size
702f0-knock sensor diagnostic min fails per sample to set DTC
702f2-knock sensor diagnostic test sample size
702f4-knock sensor diagnostic max KR
702f6-knock sensor diagnostic min tps
702f8-knock sensor diagnostic min ign volts
714e4-flash checksum
71502-CAT diagnostic tests per trip
71503-CAT diagnostic tests count to pass
71504-CAT diagnostic tests count to fail
7150a-idle diagonostic min tests to set dtc
71512-max idle rpm variance vs ect
71596-crank and cam sensor circuit diaognosic min ERT
71598-p0341 min fails per sample to set dtc
7159a-p0341 test sample size
7159c-p0336 min fails per sample to set dtc
7159e-p0336 test sample size
715a0-p1374 min fails per sample to set dtc
715a2-p1374 test sample size
71638-max MAF frequency
7163e-min maf frequency
71644-maximum delta airflow
7165a-p0106 max map volts vs tps vs rpm
716f4-p0106 man map volts vs tps vs rpm
7178e-p0108 and p1106 min fails per test sample to set dtc
71790-p0108 and p1106 test sample size
71792-p1107 min fails per test sample to set dtc.
71794-p1107 test sample size
71796-p0106 number of times out of range to set p0106
7179a-p0108 min fails tper test sample to set DTC
7179c-p0108 rpm threshold
7179e-p0108 test sample size
717a0-p0107 min fails per test sample to set DTC
717a2-p0107 RPM threshold
717a4-P0107 test sample size
717a6-p0108 min map volts
717a8-P0107 max map volts
717aa-p0108 max tps above rpm threshold
717ac-p0107 min tps above rpm threshold
717ae-p0108 max tps below rpm threshold
717b0-p0107 max tps below RPM threshold
717b6-p1112 min mph
717b8-p0113 min ect
717ba-p0113 max airmass
717bc-p0113 max mpH
717be-p0113 min ert
717c2-p1112 min ert
717c7-p0112 min raw IAT count
717c8-P0113 max raw IAT count
717ca-p1111 and p1112 test sample size.
717cc-P0113 min fails per test sample to set dtc
717ce-p0112 min fails per test sample to set DTC
717d0-p1111 min fails per test sample to set dtc
717d2-p1112 min fails per test sample to set dtc
717d4-p0112 and p0113 test sample size
717d6-p0030 fail time
717d8-p0300 IGNV thresholds
717dc-p0230 fail time
717de-p0230 ignv thresholds
717e2-p0403 fail time
717e4-p0403 ignv thresholds
717e8-p0654 fail time
717ea-p0654 ignv thresholds
717ee-p1689 fail time
717f0-p1689 ign v thresholds
71860-p1121 min fails per test sample to set dtc
71862-p1121 test sample size
71864-p1122 min fails per test sample to set dtc
71866-p1122 test sample size
71868-p0121 min ect
7186a-p0121 min ert
7186c-p0121 min fails per test sample to set DTC
7186e-high TPS diagonostic max map
71870-low TPS diagnostic min map
71876-p0121 test sample size
71878-p0123 min fails per test sample to set dtc
7187a-p0123 test sample size
7187c-p0122 min fails per test sample to set dtc
7187e-p0122 test sample size
71880-p0123 min tps volts
71882-p0122 max tps volts
71884-high TPS diagnostic predicted TPS vs RPM
718a4-low tps diagnostic predicted TPS vs RPM
71e16-misfire max delta time-low rpm-cyl mode
71f48-misfire max delta time-mid rpm-cyl mode
7209c-misfire max delta time-high rpm-cyl mode
721ce-misfire max delta time-low rpm-rev mode
72300-misfire max delta time-mid rpm-rev mode
72454-misfire max delta time-high rpm-rev mode
725c8-misfire detection disable coolant temp
725ca-misfire detection enable coolant temp
725c5-misfire detection min ect coldstart
725d0-misfire detection coldstart ECT definition
725d2-misfire detection high rpm threshold
725d4-misfire detection low rpm threshold
725b5-firing order
72646-p0130 and p0150 min ect
7264a-p0130 and p0150 min ert
7264e-p0130 and p0150 rpm thresholds
72654-p0130 and p0150 airmass thresholds
7265c-p0130 and p0150 tps thresholds
72658-p0130 and p0150 ignV thresholds
7265a-p0130 and p0150 conditions enable time
72794-p0132 and p0152 min fails per sample to set dtc while in pe
72796-p0138 min fails per sample to det dtc whlie in pe
7279a-p0132 and p0152 test sample size while in pe
7279c-p0138 test sample size while in pe
727a0-p0132 and p0152 max o2mv in DFCO
727a1-p0138 max o2 mv in dfco
727a8-p0131 and p0151 min fails per sample to set dtc
727aa-p0137 min fails per sample to set dtc
727c0-p0131 and p0151 test sample size
727c2-p0137 test sample size
727c6-p0131 and p0151 max o2 mv
727c7-p0137 max o2 mv
727d8-p0134 and p0154 min fails per sample to set dtc
727da-p0140 min fails per sample to set dtc
727de-p0134 and p0154 max o2 mv
727df-p0140 max o2 Mv
727e2-p0134 and p0154 min o2 mv
727e3-p0140 min o2 mv
727e6-p0134 and p0154 test sample size
727e8-p0140 test sample size
727ec-p0131 and p0151 min fails per sample to set dtc while in pe
727ee-p0137 min fails per sample to set dtc while in pe
727f2-p0131 and p0151 test sample size while in pe
727f4-p0137 test sample size while in pe
727f8-p0131 and p0151 max mv while in pe
727f9-p0137 max Mv while in pe
72816-p0137 max Mv while in pe
72818-p0138 min fails per sample to set dtc
72822-p0132 and p0152 max o2 mv
72823-p0138 max 02 Mv
7282e-p0132 and p0152 test sample size
72830-p0138 test sample size
72b4a-fuel trim diagonostic minimum baro
72b4c-fuel trim diagnostic ECT thresholds
72b52-fuel trim diagnostic airmass thresholds
72b5a-fuel trim diagnostic minimum fuel level
72b5c-fuel trim diagnostic MAP KPA thresholds
72b60-fuel trim diagnostic IAT thresholds
72b68-fuel trim diagnostic intrusive mode airmass thresholds
72b70-fuel trim diagnostic intrusive mode min RPM
72b78-fuel trim diagnostic RPM thresholds
72b7c-fuel trim diagnostic maximum MPH
72bb6-idle diagnostic min baro
72bb8-idle diagnostic min ect
72bbe-idle diagnostic min IAT
72bc0-idle diagnostic IGNV thresholds
72bc8-idle diagnostic max TPS
72bca-idle diagnostic max MPH
72bda-p0101 EGR limits
72bde-p0101 max map
72be0-p0101 ignV thresholds
72be6-p0101 max airmass
72be8-p0101 max delta map
72bea-p0101 max evap purge percent
72bec-p0101 criteria enable time
72bee-p0101 TPS thresholds
72c1a-dtc fault type
72d0a-DTC fault enabled
72eec-egr disable run time vs start run coolant
72f3c-egr air temp disable
72f40-egr enable tps threshold
72f42-egr disable tps threshold
72f44-egr enable speed
72f46-egr disable speed
743a8-open loop af by RPM vs airmass
74784-Fuel level percent vs fuel level sensor volts
7482c-class 2 fan enable
74834-fan 1 ambient temp
74838-fan 1 coolant temp
7483c-fan 1 pressure
74840-fan 1 coolant vs vehicle speed
74844-fan 1 pressure vs speed
7484c-fan 2 coolant temp
74848-fan 1 keyoff coolant
7484a-fan 1 keyoff time
74850-fan 2 pressure
74854-fan 2 coolant vs speed
74858-fan 2 pressure vs speed
7486a-use filtered tps
7486b-WOT diables AE
7486c-disable tps closing delta
74870-AE TPS re-allow
74872-enable tps delta vs ect
748be-tps filter coefficient
748c0-AE disable ref count limit
748c2-AE modifier vs baro
748d6-AE MPH modifier
748e8-AE enrichment vs TPS max delta
74912-accel enrichment vs ref counts
74994-startup ae modifier vs ect vs ert-p/n
74aac-startup ae modifier vs ect vsert-in gear
74b56-closed loop desired a/f
74bc4-startup ae modifier ae vs tps.
74bda-startup ae modifier vs afr correction
74d48-open loop AF be rpm vs airmass ect threshold
75390-open loop base af by coolant temp
753b6-max startup ect for startup AFR coolant
753bc-max startup ect for startup afr coldstart
753fc-torque abuse a/f
753fe-torque abuse differential score a/d
75400-traction control desired a/f
7540e-over high MPH limit AFR
75410-rpm limit afr
75436-engine over temp a/f ratio
7546e-base PE a/f vs ECT
75494-pe rpm vs time a/f
755c6-PE a/f vs tps
755f2-Catalytic converter overtemp a/f ratio
75614-startup a/f enable time vs ect
75686-startup a/f adjustment by coolant temp
7587e-decay vs startupvs rpm-p/n
7590a-decay vs startup vs rpm-in gear
75a28-hot open loop fuel enable coolant temp
75a2a-hot open loop fuel disable coolant temp
75a30-hot open loop fuel IAT thresholds
75a34-hot open loop fuel MGcyl thresholds
75a38-hot open loop fuel MPH thresholds
75a3c-CAT protection coolant
75bde-engine runtime for cosed loop vs ECT
75c04-closed loop fuel enable coolant temp
75c06-closed loop fuel disable coolant temp
75c0a-closed loop fuel enable RPM
75c0c-closed loop fuel enable RPM time
75c12-pe mode delay rpm
75c14-rpm limit afr time
75c16-rpm limit afr threshold
75c18-pe delay vs tps
75c42-pe enable tps
75c64-pe enable cylinder mass air vs rpm
75c86-pe enable mass air threshold hysteresis
75c88-pe mass air enable threshole modifier vs baro
75ca6-torque abuse drive rpm
75caa-torque abuse drive injector disable
75cab-torque differemtial score injector disable
75cac-traction control # of injectors disabled vs tc mode
75cb8-traction disable injectors
75cc0-min rpm for MPH shutoff
75cc2-disable all injectors high MPH
75cce-disable 1 injector high MPH
75cd0-disable 2 injectors high MPH
75cd2-high RPM PN fuel cutoff
75cd6-high RPM REV fuel cutoff
75cda-high RPM fuel cutoff
75cde-DFCO disable TPS threshold
75ce0-DFCO enable coolant temp
75d00-DFCO enable/disable RPM threshold vs gear
75d16-DFCO disable vehicle speed
75d18-DFCO disable vehicle speed (cruise mode)
75dc6-de use filtered TPS
75dc8-disable positive tps delta
75dcc-enable negative tps delta
75dd0-de tps filter coefficient
75dd2-de disable ref count limit
75dd4-decel enlean vs TPS
75dfe-decel enlean modifer vs ref counts
75e3c-de modifier vs ect vs gear
75e64-de modifier vs vacuum
75e72-low pulse width injector offset vs pulse width vs map
75fea-prime pulse delay after powerup
75ffe-injector pulse boundary
76002-injector offset vs battery voltage
76062-end of injection pulse vs coolant temp
760bc-min evap purge percent
760c0-LTFT enleanment calc enabled
760c1-fuel trim cals use FTCO table
760c2-LTFT min ECT
760c4-LTFT max negative trim
760ec-LTFT offset for FTcell change
760fc-blm update enable coolant temp
760fe-STFT threshold needed to change LTFT
76106-max LTFT with maf failure
7610a-min LTFT with maf failure
76118-max LTFT with evap off
7611c-max LTFT with evap on
76120-min LTFT with evap off
76124-min LTFT with evap on
76128-FTC3 enable cylair
7612a-FTC3 disable cylair
7612c-FTC3 enable TP angle
7612e-FTC3 disable TP angle
76130-FTC3 enable RPM delta
76132-FTC3 disable RPM delta
76134-FTC1 disable cylair
76136-FTC enable cylair
76138-FTC disable TP angle
7613a-FTC1 enable TP angle
7613c-FTC enable MAF airflow rate
7613e-FTC4 disable MAF airflow rate
76140-FTCO disable RPM
76142-FTCO enable RPM
76144-FTCO disable TP angle
76146-FTCO enable TP angle
76148-FTCO disable mph
7614a-FTCO enable MPH
76156-FT learn min startup ECT
76158-ft learn min ERT
7615e-LTFT change vs rich/lean staus vs airmass
761ee-IFR lookup mode
76216-injector flow rate
76252-min injector pulse width
7625e-crank fuel vs RPM
762a8-crank fuel correction vs # ref counts
7636c-crank fuel correction vs crank RPM
763ae-crank fuel correction vs TPS
763ba-crank fuel correction vs baro
763ce-injector skew percent rough idle
763da-injector skew percent
7676a-base pulse width correction vs fuel pump flow
7678c-IPW correction vs IAT
768a6-2 speed fuel pump
768aa-fuel pump high speed disable ign volts
768ac-fuel pump high speed enable IGN volts
768ae-fuel pump high speed enable MAP
768b0-fuel pump high speed disable MAP
768b2-fuel pump high speed enable flow
768b4-fuel pump high speed disable flow
768be-fuel pump prime time
768c4-o2 sensor rich/lean threshold
768dc-STFT offset vs ftcell
76918-STFT offset engine cold ect max ect
7691a-max STFT
7691e-min STFT
76922-o2 sensor rich lean transition time at idle
76926-o2 sensor rich lean transition time vs airmass not idle
76938-base STFT table vs FTcell
769c2-CAT diagnostic enable coolant temp
769c6-o2 rich threshold offset min STFT
76bd9-enable bank 2 fuel trims
76bda-fuel mileage DIC readout multiplier
76bdc-hot light enable coolant temp
76bde-hot light disable coolant temp
76be6-IAC motor reset position vs baro
76bfa-IAC motor reset position offset vs ambient air temp
76c12-IAC airflow per step
76c54-IAC airflow correction vs oil temp
76c68-IAC airflow offset for fan 1 on
76c7a-IAC airflow offset for fan 2 on
76c7c-IAC airflow offset vs coolant temp vs ERT
76cd0-IAC airflow correction vs a/c pressure
76d02-IAC PN offset hi lo MPH threshold
76d04-IAC airflow offset for PN vs RPM
76d48-IAC airflow offset vs gear vs rpm
76e4a-IAC underflow dead band in PN
76e4c-IAC underflow dead band in drive
76e83-IAC overflow dead band vs % tPS
76f32-IAC correction for a/c snticipate vs a/c pressure
76f5e-IAC for a/c anticipate correctoin factor vs RPM
76fd4-IAC pn to drive added steps vs coolant temp
770f2-IAC rev to drive anticipate steps vs vehicle speed
7711c-IAC steps added for fan 1 on
7711e-IAC steps added for fan 2 on
77320-idle RPM offest vs baro
7738a-IAC desired idle RPM for trans not engaged
773d6-IAC desired idle RPM for trans engaged
775fe-throttle follower disable delay vs gear
7771c-throttle follower disable filter time constant vs ger
77d64-throttle follower gain factor vs vehicle speed
77ff9-use larger table steps
77ffa-MAP scaling factor
77ffc-MAP sensor offset
78000-defaul max map
780d4-default map vs tps vs rpm
7824a-default map vs ECT multiplier
78270-default map vs IAT multiplier
78296-default map vs egr multiplier
782ac-o2 sensor b2s1 present
78304-decel fuel cutoff spark advance
78306-warmup spark correction vs baro multiplier
7831a-low octane/bad fuel spark
785ba-high octane/good fuel spark
7885a-mean best torque spark
78afa-decel spark advance multiplier ve coolant temp
78b0e-decel spark advance multiplier vs ambient temp
78b22-decel spark advance vs RPM
78b3e-decel spark disable %tps
78b40-decel spark enable %tps
78b44-decel spark advance enable coolant temp
78b98-torque abuse spark
78b9a-max allowable spark advance
78b9c-min allowable spark advance
78ba0-min allowable spark advance- torque management
78bbe-egr spark advance correction vs load vs rpm
78cfe-egr spark advance correction vs load bs rpm, high alt.\
78e52-launch spark disable vehicle speed
78e56-launch sparnk enable pos delta TPS
78e58-launch spark enable pos delta mass air
78e5a-launch spark disable pos delta mass air
78e5e-launch spark diasble negative delta TPS
78e60-launch spark advance correction vs load vs rpm
78fda-launch spark correction multiplier vs coolant temp
79002-min power managment spark advance
79004 power management spark retard vs pm mode
79012-power managment spark retard adder vs pm mode vs tps
79106-spark advance p/n correction vs coolant temp
79140-tcc spark advance correction
792c0-AFR spark modifier
791c2-warmup spark correction vs load vs engine runtime
792d0-air temp spark modifier
79470-engine coolant temp spark modifier
796d6-high RPM threshold
796d8-high RPM spark
796da-egr spark modifier
79a50-idle spark enable coolant temp
78a52-idle spark disable coolant temp
79a78-idle spark advance vs load vs rpm
79acc-disable idle spark advance vs ect multiplier
79ace-idle spark advance multipliervs coolant temp
79b1a-closed loop idle spark correction afr-ap on
79b5e-closed loop idle spark correction AFR-ap off
79ba4-torque differential score retard
79ba8-high MPH limit
79bb6-warmup spark correction vs mph multiplier
79bc8-warmup spark max ert vs startup ect
79fec-min est signal high time
79fee-min est signal low time
79ff0-static dwell time vs reference period
7a03a-dwell time correction vs battery voltage
7a068-lower window limit dwell time multiplier vs rpm
7a08e-upper window limit dwell multiplier vs rpm
7a0b4-max main dwell table correction vs ign temp ve ign volt
7a280-max dwell time vs ign volt vs rpm
7a5ea-dwell time correction vs %egr
7a9cc-main dwell table correction vs ignition volt
7ab98-main spark dwell time vs ign volts vs rpm
7af10-burst knock disable RPM
7af12-burst knock disable MPH
7af14-burst knock detection min delta TPS
7af16-burst knock retard enable coolant temp
7af1c-max burst knock control
7af22-cyl air threshold
7af24-kncok retard recovery rate
7af46-knock retard decel recovery rate
7af68-knock retard IR attack rate
7af92-max allowed spark retard
7afa0-spark control runtime disable
7afa2-spark control coolant disable
7afa4-spark control rpm disable
7afa6-knock retard defaul value
7afb4-knock retard default max
7afc2-default KR vs MgCyl multiplier
7afe2-default KR vs rpm multiplier
7aff4-spark control map disable
7b124-traction mode boost control by torque
7b126-traction mode boost control disable
7b128-decel boost control MPH
7b12a-decel boost control by throttle
7b12c-integral gain
7b12e-porportional gain
7b130-boost ramp rate
7b132-excess MPH boost reduction gain
7b134-excess MPH torque reduction scalar
7b136-excess MPG enable timer
7b138-excess MPH enable by MPH
7b6e2-shift pressure 2nd base
7b724-shift pressure 3rd base
7b766-shift pressure 4th base
7b7a8-shift pressure 2nd performance
7b7ea-shift pressure 3rd performance
7b82c-shift pressure 4th performance
7b86e-2nd base pressure correction VS torque vs trans temp
7b918-3rd base pressure correction vs torque vs trans temp
7b9c2-4th base pressure correction vs torque vs trans temp
7ba6c-2nd downshift pressure correction vs torque vs trans temp
7bb16-3rd downshift pressure correction vs torque vs trans temp
7bbc0-4th downshift pressure correction vs torque vs trans temp
7bc6a-braking pressure 1st
7bc8c-braking pressure 2nd
7bcae-braking pressure 3rd
7bd90-2nd upshift pressure multiplier vs torque vs ratio
7be3a-3rd upshift pressure multiplier vs torque vs ratio
7bee4-4th upshift pressure multiplier vs torque vs ratio
7bf96-calculated pulses per revolution
7bf98-abuse mode duration vs trans temp
7bfdc-torque reduction 2nd to 1st downshift
7bffe-torque reduction 3rd to 2nd downshift
7c020-torque reduction 4th to 3rd downshift
7c042-torque reduction 1st to 2nd upshift
7c064-torque reduction 2nd to 3rd upshift
7c086-torque reduction 3rd to 4th upshift
7c0a8-torque reduction 1st to 2nd performance upshift
7c0ca-torque reduction 2nd to 3rd performance upshift
7c0ce-torque reduction 3rd to 4th performance upshift
7c130-1st to 2nd normal shift line
7c152-2nd to 3rd normal shift line
7c174-3rd to 4th normal shift line
7c196-2nd to 1st normal line
7c1b8-3rd to 2nd normal line
7c1da-4th to 3rd normal line
7c1fc-2nd to 3rd cruise shift line
7c21e-3rd to 4th cruise shift line
7c240-3rd to 2nd cruise shift line
7c262-4th to 3rd cruise shift line
7c284-1st to 2nd d2 normal line
7c2a6-2nd to 3rd d2 normal line
7c2a8-2nd to 1st d2 normal line
7c3c2-2nd to 3rd hot normal line
7c2ca-3rd to 2nd d2 normal line
7c2cc-1st to 2nd dlow normal line
7c2ce-2nd to 3rd dlow normal line
7c2d0-2nd to 1st dlow normal line
7c2d2-3rd to 2nd dlow normal line
7c3a0-1st to 2nd hot normal line
7c3e4-3rd to 4th hot normal line
7c406-2nd to 1st hot normal line
7c428-3rd to 2nd hot normal line
7c44a-4th to 3rd hot normal line
7c46c-1st to 2nd performance shift
7c48e-2nd to 3rd performance shift line
7c4b0-3rd to 4th performance shift line
7c4d2-2nd to 1st performance shift line
7c4f4-3rd to 2nd performance shift line
7c516-4th to 3rd performance shift line
7c538-1st to 2nd WOT shift
7c53a-2nd to 3rd wot shift
7c53c-3rd to 4th WOT shift
7c53e-2nd to 1st WOT shift
7c540-3rd to 2nd WOT shift
7c542-4th to 3rd WOT shift
7c544-1st to 2nd hot WOT shift
7c546-2nd to 3rd hot WOT shift
7c548-3rd to 4th hot WOT shift
7c54a-2nd to 1st hot WOT shift
7c54c-3rd to 2nd hot WOT shift
7c54e-4th to 3rd hot WOT shift
7c550-1st to 2nd performance WOT shift
7c552-2nd to 3rd performance WOT shift
7c554-3rd to 4th performance WOT shift
7c556-2nd to 1st performance WOT shift
7c558-3rd to 2nd performance WOT shift
7c55a-4th to 3rd performance
7c566-1st to 2nd shift RPM
7c568-2nd to 3rd shift RPM
7c56a-3rd to 4th hot shift RPM
7c56c-1st to 2nd hot shift RPM
7c56e-2nd to 3rd hot shift RPM
7c570-3rd to 4th hot shift RPM
7c578-1st to 2nd performance shift RPM
7c57a-2nd to 3rd performance shift RPM
7c57c-3rd to 4th performance shift RPM
7c584-1st to 2nd dlow urban line
7c5a6-2nd to 3rd dlow urban line
7c5c8-2nd to 1st dlow urban line
7c5ea-3rd to 2nd dlow urban line
7c85e-TCC apply 2nd normal line
7c880-TCC apply 3rd normal line
7c8a2-TCC apply 4th normal line
7c8c4-TCC release 2nd normal line
7c8e6-TCC release 3rd normal line
7c908-TCC release 4th normal line
7c92a-TCC apply 3rd cruise
7c94c-TCC apply 4th cruise
7c96e-TCC release 3rd cruise
7c990-TCC release 4th cruise
7c9b2-TCC apply 2nd hot
7c9d4-TCC apply 3rd hot
7c9fc-TCC apply 4th hot
7ca18-TCC release 2nd hot
7ca3a-TCC release 3rd hot
7ca5c-TCC release 4th hot
7ca7e-TCC apply 2nd performance
7caa0-TCC apply 3rd performance
7cac2-TCC apply 4th performance
7cae4-TCC release 2nd performance
7cb06-TCC release 3rd performance
7cb28-TCC release 4th performance
7cd5a-normal TCC release %tps threshold vs gear vs speed
7cdc0-cruise TCC release %tps threshold vs gear vs speed
7ce26-performance tcc release %tps threshold vs gear vs speed
7ce8c-1st to 2nd normal shift time
7ceae-2nd to 3rd normal shift time
7ced0-3rd to 4th normal shift time
7cef2-1st to 2nd performance shift time
7cf14-2nd to 3rd performance shift time
7cf36-3rd to 4th performance shift time
7d08a-shift switch type
7d08c-discrete switch debounce time
7d09a-IAT sensor present
7d09b-shift quality controled by pcm
7d0a5-trans torque reduction-master enable
7d0a6-trans abuse mode master enable
7d0e2-abuse control method
7d0e4-max turbine torque TCC locked
7d0fe-max turbine torque TCC unlocked
7d186-brake torque limit
7d2a0-torque abuse speed enable
7d2a2-torque abuse throttle enable
7d2a6-torque abuse rpm enable
7d2a8-torque abuse time enable
7d2b0-torque management engine speed limit
7d2b4-torque abuse spark retard
7d2e4-torque abuse differential score mph enable
7d33c-Catalyst protection boost shutoff
7d39c-traction control enable coolant temp
7d5e8-transmission type
7d5f2-1st gear min rpm/vehicle speed ratio
7d5fc-2nd gear min rpm/vehicle speed ratio
7d620-speedometer input pulses per revolution
7d634-pulses per mile
7d644-VTD present on car
7d64e-VTD injector disable time
7d654-VTD auto learn timer
7d65c-VTD auto learn counter
7d70e-tcc slip test fail slip rpm low
7d710-tcc slip test fail slip rpm high
7d734-tcc slip diagnostic disable rpm
7d736-tcc slip diagnostic enable rpm
7d9ae-max shift pressure
7d9b0-drive sproket ratio
7d9d4-first gear ratio
7d9d6-second gear ratio
7d9d8-third gear ratio
7d9da-fourth gear ratio
7d9dc-reverse gear ratio
7ea1a-trans abuse mode-min rpm
7ea1c-trans abuse mode-max trans rpm
7ea1e-trans abuse mode-min tps%
7ea22-trans abuse mode-max MPH
7ea24-trans abuse mode-torque reduction
7ee4e-downshift delay after tcc unlock
7eee4-tcc upshift unlock time vs gear
7eeec-tcc downshift unlock time vs gear
7effa-tcc dc max-line pressure vs trans temp
7f076-tcc dc min-line pressure vs trans temp
7f120-tcc pressure apply rate
7f9ce-FMC vs CLP vs temp-positive
7fb0e-torque step size for table lookup
7fbf4-trans revolutions per mile
7fffa-prom id
7fffe-programming complete pattern
6f1dc-engine type
6fbea-default baro
717b6-p1112 min mph
717b8-p0113 min ect
717bc-p0113 max mpH
717be-p0113 min ert
717c2-p1112 min ert
71868-p0121 min ect
7186a-p0121 min ert
725b5-firing order
72bde-p0101 max map
75410-rpm limit afr
755c6-PE a/f vs tps
75c42-pe enable tps
760c2-LTFT min ECT
7691a-max STFT
7691e-min STFT
7b12c-integral gain
7fffa-prom id
Cool. Thanks for sharing.
What does tiny tuner do, exactly?
Definition file generator? Disassembler?
I did all of that using a utility made by the people who made tiny tuner, tiny tuner is just a tuning program for GM V6 PCM's
http://theblattners.com/Projects/TinyTuner/default.html
this is their "bin editor" that lets you add tables to their database:
http://theblattners.com/Projects/Binary ... fault.html
I'm thinking I'm going to tackle this with a different osid though, there are other osid's that are more hacked already that may be a better starting point.
I was wondering what it would take with that package to figure out what the PID's are for my Shelby OS.
I @$$ume that the first four bytes of the .bin file are the OSID in OBDII apps?
So you're working with the Shortstar OS, but you want to start with a different OS (assuming written for the same PCM) that's better hacked? What are your options in that regard? You said that the V6 OS's all have the capability to read 3800, 60 degree and Shortstar (LS1) crank sensors, and you just need to find the right code switch to tell it which one. You've found that switch, right?ericjon262 wrote:I did all of that using a utility made by the people who made tiny tuner, tiny tuner is just a tuning program for GM V6 PCM's
tiny tuner may work, but you might be better off with dimented24x7's adx's to tune LS1's with tunerpro,The Dark Side of Will wrote:I was wondering what it would take with that package to figure out what the PID's are for my Shelby OS.
http://www.gearhead-efi.com/Fuel-Inject ... CM-Project!
if nothing else, it should give you a foundation to build off of.
The Dark Side of Will wrote:So you're working with the Shortstar OS, but you want to start with a different OS (assuming written for the same PCM) that's better hacked? What are your options in that regard? You said that the V6 OS's all have the capability to read 3800, 60 degree and Shortstar (LS1) crank sensors, and you just need to find the right code switch to tell it which one. You've found that switch, right?ericjon262 wrote:I did all of that using a utility made by the people who made tiny tuner, tiny tuner is just a tuning program for GM V6 PCM's
I've noticed a few switches and flags in the bin, and I'm starting to think that any of the V6 osid's may be able to control any of the V6's, specifically the "crank sensor resolution flag", and the "engine type" flag. my biggest concern at the moment, is that the tiny tuner database for the shortstar appears to have several errors, I can't validate it 100% yet, but some things just aren't matching up the way I would expect.
whoo... 721 parameters. this is a "L67" bin, about 40 more then the short* bin, but I think it will be able to be adjusted for COP by simply changing the "engine type", and "crank sensor resolution" switches, it also supports boost out of the box, no questions asked.
there are a couple of oddities in tiny tuner here though;
two tables, one address
75a66-pe enrichment rate - rev limit hits for rev limit afr
one table, two addresses
6f2f4-speed density maf compensation vs baro
6f31c----speed density maf compensation vs baro
I haven't investigated any of it yet. I'll report back with findings...
1d12a-ect vs voltage
23c18-injector firing reference vs engine type 1
23c42-injector firing reference vs engine type 2
4c544-engine displacement vs engine type
6ee51-car type
6ee52-ignore flash checksum
6ee53-disable flash security
6ee54-module programmed
6ee56-engine type
6ee57-crank sensor resolution
6ee58-supercharger rpesent
6ee60-immediate a/c rpm disable
6ee66-a/c disable rpm
6ee6a-a/c rpm re-enable
6ee70-a/c on startup delay
6ee84-a/c min air temp
6ee86-a/c disable/re-enable ect
6ee8a-a/c disable/re-enable tps
6ee8e-a/c disable timer
6eea6-a/c ign voltage disable
6eeaa-a/c ign voltage enable
6eeb2-maf airflow table
6ef54-maf max positive airflow change
6ef7a-maf max negative airflow change
6f016-transient airmass calc mode
6f018-max cyl airmass
6f01e-transient fueling enable positive tps delta
6f020-transient fueling enable negative tps delta
6f028-default mass airflow (gm/sec) vs tps vs rpm
6f2f2-maf failure airmass calc mode
6f308-speed density maf compensation vs ect
6f3b4-volumetric efficiency
6f5b2-ve correction vs tps vs egr state
6f5ca-speed sensity maf compensation vs IAT
6f75e-air pump system present
6f774-air pump enable startup coolant temp
6f7a8-alternator startup delay vs ect
6f7bc-alternator rpm cutout
6f840-default baro
6f842-always use default baro
6f846-sc baro lookup
6f888-na baro lookupvs tps vs rpm
6faa4-o2sensor config for pid 13
6faa6-boost delay-boost timer base
6fabc-boost delay-timer adder-tcs on
6fb00-boost delay-timer adder-tcs off
6fb54-CCP enable coolant temp
700a6-ect ok enable ert
700a8-ect ok enable ect
700aa-ect ok disable ect
700ac-ect ok enable dtc set
700ae-ect ok disable ect dtc set
700b0-ect temp vs ert
7031c-knock sensor diagnostic min ect
7031e-knock sensor diagnostic min engine load
70320-knock sensor diagnostic rpm thresholds
7032e-knock sensor diagnostic min ert
70332-knock sensor circuit diagnostic min fails per sample to set DTC
70334-knock sensor circuit diagnostic test sample size
70336-knock sensor diagnostic min fails per sample to set dtc
70338-knockc sensor diagnostic test sample size
7033a-knock sensor diagnostic max KR
7033c-knock sensor diagnostic min tps
7033e-knock sensor diagnostic min ignv
70f4c-flash checksum
70f7a-CAT diagnostic tests per trip
70f7c-CAT diagnostic count to fail
70f82-idle diagnostic min tests failed to set dtc
70f8a-max idle rpm variance vs ect
70fda-cam and crank sensor circuit min ert
70fdc-p0341 min fails per sample to set dtc
70fde-p0341 test sample size
70fe0-p0336 min fails per sample to set dtc
70fe2-p0336 test sample size
70fe4-p1374 min fails per sample to set dtc
70fe6-p1374 test sample size
71080-p0103 min fails per test sample to set dtc
71082-p0103 test sample size
71084-max maf frequency
71086-p0102 min fails per test to set dtc
71088-p0102 test sample size
7108a-min maf frequency
7108c-p0101 min fails per sample to set dtc
7108e-p0101 test sample size
71090-max delta airflow
710a6-p0106 max map volts vs tps vs rpm
71140-p0106 min map volts vs tps vs rpm
711da-p0108 and p1106 min fails per test sample to set dtc
711dc-p0108 and p1106 test sample size
711de-p1107 min fails per sample to set dtc
711e0-p1107 test sample size
711e2-p0106 number of times out of range to set p0106
711e6-p0108 min fails per test sample to set dtc
711e8-p0108 rpm threshold
711ea-p0108 test sample size
711ec-p0107 min fails per test sample to set dtc
711ee-p0107 rpm threshold
711f0-p0107 test sample size
711f3-p0108 min map volts
711f4-p0107 max map volts
711f6-p0108 max tps above rpm threshold
711f8-p0107 min tps above rpm threshold
711fa-p0108 max tps below rpm threshold
711fc-p0107 max tps below rpm threshold
71202-p1112 min mph
71204-p0113 min ect
71206-p0113 max airmass
71208-p0113 max mph
7120a-p0113 min ert
7120e-p1112 min ert
71213-p0112 min raw iat count
71214-p0113 max raw iat count
71216-p1111 and p1112 tests sample size
71218-p0113 min fails per test sample to set dtc
7121a-p0112 min fails per test sample to set dtc
7121c-p1111 min fails per test sample to set dtc
7121e-p1112 min fails per test sample to set dtc
71220-p0112 and p0113 test sample size
71222-p0030 fail time
71224-p0030 ign v thresholds
71228-p0230 fail time
7122a-p0230 ign v thresholds
7122e-p0403 fail time
71230-p0403 ign v thresholds
71234-p0654 fail time
71236-p0654 ign v thresholds
7123a-p1689 fail time
7123c-p1689 ign v thresholds
712ac-p1121 min fails per test sample to set dtc
712ae-p1121 test sample size
712b0-p1122 min fails per test sample to set dtc
712b2-p1122 test sample size
712b4-p0121 min ect
712b6-p0121 min ert
712b8-p0121 min fails per test sample to set dtc
712ba-high tps diagnostic error max map-p0121
712bc-low tps diagnostic min map
712c2-p0121 test sample size
712c4-p0123 min fails per test sample to set dtc
712c6-p0123 test sample size
712c8-p0122 min fails per test sample to set dtc
712ca-p0122 test sample size
712cc-p0123 min tps volts
712ce-p0122 max tps volts
712d0-high tps diagnostic predicted tps vs rpm
712f0-low tps diagnostic predicted tps vs rpm
71862-misfire max delta time low rpm cyl mode
71994-misfire max delta time mid rpm cyl mode
71ae8-misfire max delta time high rpm cyl mode
71c1a-misfire max delta time low rpm rev mode
71ea0-misfire max delta time high rpm rev mode
71d4c-misfire max delta time mid rpm rev mode
7200a-misfire firing order lookup
7201c-misfire detection coldstart ect definition
72014-misfire detection disable coolant temp
72016-misfire detection enable coolant temp
7201a-misfire detection min ect coldstart
7201e-misfire detection high rpm threshold
72020-misfire detection low rpm threshold
72092-p0130 and p0150 min ect
72096-p0130 and p0150 min ert
7209a-p0130 and p0150 rpm thresholds
720a0-p0130 and p0150 airmass thresholds
720a4-p0130 and p0150 ign v thresholds
720a6-p0130 and p0150 conditions enable time
720a8-p0130 and p0150 tps thresholds
72204-p0132 and p0152 min fails per sample to set dtc while in pe
72206-p0138 min fails per sample to set dtc while in pe
7220a-p0132 and p0152 test sampel size while in pe
7220c-p0138 test sample size while in pe
72210-p0132 and p0152 max o2 mv in dfco
72211-p0138 max o2 mv in dfco
72218-p0131 and p0151 min fails per sample to set dtc
7221a-p0137 min fails per sample to set dtc
72230-p0131 and p0151 test sample size
72232-p0137 test sample size
72236-p0131 and p0151 max o2 mv
72237-p0137 max o2 mv
72248-p0134 and p0154 min fails per sample to set dtc
7224a-p0140 min fails per sample to set dtc
7224e-p0134 and p0154 max o2 mv
7224f-p0140 max o2 mv
72252-p0134 and p0154 min o2 mv
72253-p0140 min o2 mv
72256-p0134 and p0154 test sample size
72258-p0140 test sample size
7225c-p0131 and p0151 min fails per sample to set dtc while in pe
7225e-p0137 min fails per sample to set dtc while in pe
72262-p0131 and p0151 test sample size while in pe
72264-p0137 test sample size
72268-p0131 and p0151 max mv while in pe
72269-p0137 max mv while in pe
72286-p0132 and p0152 min fails per sample to set dtc
72288-p0138 min fails per sample to set dtc
72292-p0132 and p0152 max o2 mv
72293-p0138 max o2 mv
7229e-p0132 and p0152 test sample size
722a0-p0138 test sample size
72988-fuel trim diagnostic min baro
7298a-fuel trim diagnostic ect thresholds
72990-fuel trim diagnostic airmass thresholds
72998-fuel trim diagnostic min fuel level
7299a-fuel trim diagnostic map kpa thresholds
7299e-fuel trim diagnostic iat thresholds
729a6-fuel trim diagnostic intrusive mode airmass thresholds
729ae-fuel trim diagnostic intrusive mode min rpm
729b6-fuel trim diagnostic RPM thresholds
729ba-fuel trim diagnostic max MPH
729fc-idle diagnostic min baro
729fe-idle diagnostic min ect
72a00-idle diagnostic min ert
72a04-idle diagnostic min iat
72a06-idle diagnostic ign v threshold
72a0e-idle diagnostic max tps
72a10-idle diagnostic max MPH
72a16-p0102 and p0103 min ert
72a1a-p0102 and p0103 min iac steps
72a1c-p0102 and p0103 min ign v
72a1e-p0102 and p0103 min rpm
72a20-p0102 and p0103 criteria enable time
72a22-p0101 egr limits
72a26-p0101 max map
72a28-p0101 ign v thresholds
72a2e-p0101 max airmass
72a30-p0101 max delta map
72a32-p0101 max evap purge percent
72a34-p0101 criteria enable time
72a36-p0101 tps thresholds
72a62-dtc fault type
72b54-dtc fault enabled
72d3c-egr disable run time vs startrun coolant
72d8c-egr air temp disable
72d90-egr enable tps threshold
72d92-egr disable tps threshold
72d94-egr enable speed
72d96-egr disable speed
73938-enable oil pressure warning light
741f8-open loop af by rpm vs airmass
745d4-fuel level percent vs fuel level sensor volts
7467c-class 2 fan enable
74684-fan 1 ambient temp
74688-fan 1 coolant temp
7468c-fan 1 pressure
74690-fan 1 coolant temp vs vehicle speed
74694-fan 1 pressure vs speed
74698-fan 1 keyoff coolant
7469a-fan 1 keyoff time
7469c-fan 2 temp
746a0-fan 2 pressure
746a4-fan 2 coolant temp
746a8-fan 2 pressure vs speed
746ba-use filtered tps
746bb-WOT disables AE
746bc-ae disable tps closing delta
746c0-ae tps re-allow
746c2-enable tps delta vs ect
7470e-TPS filter coefficient
74710-ae disable ref count limit
74712-ae modifier vs baro
74726-ae mph modfier
74738-ae enrichment vs tps max delta
74762-accel enrichment vs ref counts
747e4-ae modifier vs ect vs ert -in gear
748fc-ae modifier vs ect ve ert -p/n
74a14-startup ae modifier vs tps
74a2a-startup ae modifier vs afr correction
74a36-closed loop desifred a/f ratio
74b98-open look af by rpm vs airmass ect threshold
74b9c-open loop af by rpm vs airmass cold ect
74ebc-open loop af by rpm vs airmass hot ect
751e0-open loop base af by coolant temp
75206-max startup ect for startup afr
75208-additional ect needed to disable coldstart status for afr vs startup ect
7524c-torque abuse a/f
7524e-torque abuse differential score a/f
75250-traction control desired a/f
7525e-over high mph limit afr
75260-rev limit mode afr
75286-engine over temp base a/f ratio
752be-base pe a/f vs ect
752e4-pe rpm vs time vs a/f
75416-pe a/f vs tps
75443-catalytic converter overtemp a/f ratio
75464-startup enable time vs ect
754d6-startuip a/f adjustment by coolant temp
756ce-decay vs startup ect vs rpm-p/n
7575a-decay vs startup ect vs rpm-in gear
75878-hot open loop fuel enable coolant temp
7587a-hot open loop fuel disable coolant temp
7587e-hot open loop fuel conditions enable time
75880-hot open loop fuel iat thresholds
75884-hot open loop fuel mg/cyl thresholds
75888-hot open loop fuel mph thresholds
7588c-CAT protection coolant
758a2-closed loop max airmass
758a4-closed loop disable airmass
75a2e-engine runtime for closed loop vs ect
75a54-closed loop fuel enable coolant temp
75a56-closed loop fuel disable coolant temp
75a58-closed loop rpm enable max ect
75a5a-closed loop fuel enable rpm
75a5c-closed loop fuel enable rpm time
75a5e-closed loop o2 mv disable time
75a60-closed loop o2 mv thresholds
75a62-pe mode delay rpm
75a64-rev limit afr active time
75a68-pe delay vs tps
75a92-pe anable tps
75ab4-pe enable cylinder airmass vs rpm
75ad6-pe enable mass air thresh hysteresis
75ad8-pe mass air enable threshole modifier vs baro
75af6-torque abuse drive rpm
75afa-torque abuse drive injector disable
75afb-torque differential score injector disable
75afc-traction control # of injectors disabled vs tc mode
75b08-traction disable injectors
75b10-min rpm for mph shutoff
75b12-disable all injectors high MPH
75b1e-disable 1 injector high mph
75b20-disable 2 injectors high MPH
75b22-high rpm pn fuel cutoff
75b26-high rpm rev fuel cutoff
75b2a-high rpm fuel cutoff
75b2e-DFCO disable tps threshold
75b30-DFCO enable coolant temp
75b50-DFCO enable/disable rpm threshold vs gear
75b66-DFCO disable vehicle speed
75b68-DFCO disable vehicle speed (cruise mode)
75c16-de use filtered tps
75c18-disable positive TPS delta
75c1c-enable negative tps delta
75c20-de tps filter coefficient
75c22-DE disable ref count limit
75c24-decel enlean vs tps
75c4e-decel enlean modifier vs ref counts
75c8c-de modifier vs ect vs gear
75cb4-de modifier vs vacuum
75cc2-low pulse width injector offset vs pulse width vs map
75e3a-prime pulse delay after powerup
75e4e-injector pulse boundry
75e52-injector offset vs battery voltage
75eb2-end of injection pulse vs coolant temp
75f10-min evap purge pct
75f14-LTFT enaleanment calc enabled
75f15-fuel trim calc use ftc0 table
75f16-LTFT min ect
75f18-LTFT max negative trim
75f40-LTFT offset for FTCell change
75f50-blm update enable coolant temp
75f52-STFT threshold needed to change LTFT
75f5a-max LTFT with maf failure
75f5e-min LTFT with maf failure
75f6c-max LTFT with evap off
75f70-max LTFT with evap on
75f74-min LTFT with evap off
75f78-min LTFT with evap on
75f7c-FTC3 mg/cyl thresholds
75f7e-FTC3 disable cylair
75f80-FTC3 TPS thresholds
75f82-FTC3 disable tp angle
75f84-FTC3 rpm thresholds
75f86-FTC3 disable RPM delta
75f88-FTC1 mg/cyl thresholds
75f8a-ftc1 enable cylair
75f8c-FTC1 tps thresholds
75f8e-FTC1 enable tp angle
75f90-ftc4 mg/cyl thresholds
75f92-FTC4 disable MAF airflow rate
75f94-FTC0 idle variance thresholds
75f96-FTC0 enable RPM
75f98-FTC0 tps thresholds
75F9a-FTC0 enable TPangle
75f9c-FTC0-mph thresholds
75f9e-FTC0 enable MPH
75fac-FT learn min ert
75fb2-LTFT change vs rich/lean status vs airmass
76042-IFR lookup mode
7606a-injector flow rate
790a6-min injector pulse width
760b0-max ect for crank fuel ref count multiplier
760b2-crank fuel vs coolant temp
760fc-crank fuel correction vs # ref counts
761c0-crank fuel correction vs crank rpm
76202-crank fuel correction vs tps
7620e-crank fuel correction vs baro
76222-injector skew percent rough idle
7622e-injector skew percent
765be-base pulse width correction vs fuel pump flow
765e0-IPW correction vs IAT
766fa-2speed fuel pump
766fe-fuel pump high speed disable ign volts
76700-fuel pump high speed enable ign volts
76702-fuel pump high speed enable map
76704-fuel pump high speed disbale map
76706-fuel pump high speed enable flow
76708-fuel pump high speed disable flow
76712-fuel pump prime time
76718-o2 sensor rich lean threshold
76730-STFT offset vs ect
7676a-max STFT
7676c-STFT offset engine cold MAX ECT
76772-min ftft
76776-o2 sensor rich lean transistion time at idle
7677a-o2 sensor rich lean transition time vs airmass not idle
7678c-base stft table vs ft cell
76816-CAT diagnostic enable coolant temp
7681a-o2 rich threshold offset min stft
76a2d-enable 2 bank fuel trims
76a2e-fuel milage DIC readout multiplier
76a30-hot light enable coolant temp
76a32-hot light disable coolant temp
76a3a-iac motor reset position vs baro
76a4e-iac motor reset position offset vs ambient air temp
76a66-iac airflow per step
76a96-iac airflow correction vs ac pressure mph multiplier
76aa8-iac airflow correction vs oil temp
76abc-iac airflow offset for fan 1 on
76abe-iac airflow offset for fan 2 on
76ac0-iac airflow offset vs coolant temp vs engine run time
76b24-IAC airflow correction vs a/c pressure
76b56-iac p/n offset hi lo mph threshold
76b58-iac airflow offset for p/n vs rpm
76b9c-iac airflow offset vs gear vs rpm
76c90-iac underflow dead band-in drive
76c9e-iac underflow dead band-p/n
76cd6-iac overflow deadband vs tps%
76d60-iac correction for ac anticipate vs ac pressure
76db2-iac for ac anticipate correction factor vs rpm
76e28-iac p/n to drive added steps vs coolant temp
76f46-iac rev to drive anticipate steps vs vehicle speed
76f70-iac steps added for fan 1 on
76f72-iac steps added for fan 2 on
77174-idle rpm offset vs baro
771de-iac desired idle rpm trans not engaged
7722a-iac desired idle rpm trans engaged
77464-throttle follower disable delay vs gear
7753a-throttle folloer gain factor vs vehicle speed
77582-throttle follower disable filter time constant vs gear
77e5f-spark table air mass scale
77e60-map scaling factor
77e62-map sensor offset
77e66-default max map
77f3a-default map vs tps vs rpm
780b0-default map vs ect multiplier
780d6-default map vs iat multiplier
780fc-default map vs egr% multiplier
78112-o2 sensor b2s1 present
7816a-decel fuel cutoff spark advance
7816c-warmup spark correction vs baro multiplier
78180-low octane/bad fuel spark
78420-high octane/good fuel spark
786c0-mean best torque spark
78960-decel spark advance multiplier vs coolant temp
78974-decel spark advance multiplier vs ambient temp
78988-decel spark advance vs rpm
789a4-decel spark disable tps
789a6-decel spark enable tps
789aa-decel spark advance enable coolant temp
789fe-torque abuse spark
78a00-max allowable spark advance
78a02-min allowable spark advabce
78a10-max spark advance in pe
78a24-egr spark adv. correction vs load vs rpm
78b64-egr spark adv. correction vs load ve rpm high alt
78cb8-launch spark disable vehicle speed
78cbc-launch spark enable positive delta tps
78cbe-launch spark enable pos delta mass air
78cc0-launch spark disable pos delta mass air
78cc4-launch spark disable negative delta tps
78cc6-launch spark advance correction vs load vs rpm
78e40-launch spark correction multiplier vs coolant temp
78e68-min power management spark advance
78e6a-power management spare retard vs pm mode
78e78-power management spark retard adder vs pm mode vs tps
78f6c-spark advance p/n correction vs coolant temp
78fa6-tcc spark advance correction
79028-warmup spark correction vs load ve engine runtime
79126-afr spark modifier
79136-air temp spark modifier
792d6-engine coolant temp spark modifier
7953c-high rpm threshold
7953e-high RPM spark
79540-crank spark advance vs rpm vs coolant temp
798b4-disable idle spark advance
798b6-idle spark enable coolant temp
798b8-idle spark disable coolant temp
798de-idle spark advance vs load vs rpm
79932-disable idle spark advance vs ect multiplier
79934-idle spark advance multiplier vs coolant temp
79980-closed loop idle spark correction-ap on
799c4-closed loop idle spark correction-ap off
79a0a-torque differential score retard
79a0e-high MPH limit
79a1c-warmup spark correction vs mph multiplier
79a2e-warmup spark max ert vs ect
79e52-min est signal high time
79e54-min est signal low time
79e56-static dwell time vs reference period
79ea0-dwell time correction vs batt voltage
79ece-lower window limit dwell time multiplier vs rpm
79ef4-upper window limit dwell time multiplier vs rpm
79f1a-max dwell table correction vs ign temp vs ign volt
7a0e6-max dwell time vs ign volt vs rpm
7a450-dwell time correction vs %egr
7a832-main dwell table correction vs ign temp vs ign volt
7a9fe-main spark dwell time vs ign volt vs rpm
7ad76-burst kr detection min rpm
7ad78-burst knock disable mph
7ad7a-burst kr detection min delta tps
7ad7c-burst kr detection max ect
7ad82-max burst knock retard
7ad88-cyl air threshold
7ad8a-knock retard recovery rate
7adac-knock retard decel recovery rate
7adce-knock retard ir attack rate
7adf8-max allowed spark retard
7aeo6-spark control runtime disable
7ae08-spark control coolant disable
7aeoa-spark control rpm disable
7ae0c-knock retard default value
7ae1a-knock retard default max
7ae28-default kr vs mgcyl multiplier
7ae48-default kr vs rpm multiplier
7ae5a-spark control map disable
7af8a-traction mode boost control by torque
7af8c-traction mode boost enable control*** error msg in tiny tuner when clicked
7af8e-decel boost control MPH
7af90-decel boost control by throttle
7af92-integral gain
7af94-porportional gain
7af96-boost ramp rate
7af98-excess MPH boost reduction gain
7af9a-excess mph reduction scalar
7af9c-excess MPH enable timer
7af9e-excess mph enable by MPH
7b07e-dtc disables shift adapts
7b0fe-dtc forces 2nd gear
7b17e-dtc disables 3 to 2 downshift above 30 MPH
7b27e-dtc disables 4th gear
7b2be-dtc disables 4th gear in hot mode
7b33e-DTC forces max line pressure
7b47e-dtc forces extra line pressure
7b4f5-dtc disables tcc lockup
7b5fe-shift pressure 2nd base
7b640-shift pressure 3rd base
7b682-shift pressure 4th base
7b6c4-shift pressure 2nd performance
7b706-shift pressure 3rd performance
7b748-shift pressure 4th performance
7b78a-2nd base correction vs torque vs trans temp
7b834-3rdbase correction vs torque vs trans temp
7b8de-4th base correction vs torque vs trans temp
7b988-2nd downshift pressure correction vs torque vs trans temp
7ba32-3rd downshift pressure correction vs torque vs trans temp
7badc-4th downshift pressure correction vs torque vs trans temp
7bb86-braking pressure 1st
7bba8-braking pressure 2nd
7bbca-braking pressure 3rd
7bcac-2nd upshift pressure multiplier vs torque vs ratio
7bd56-3rd upshift pressure multiplier vs torque vs ratio
7be00-4th upshift pressure multiplier vs torque vs ratio
7beb2-calculated pulses per revolution
7beb4-abuse mode duration vs trans temp
7bef8-torque reduction 2nd to 1st downshift
7bf1a-torque reduction 3rd to 2nd downshift
7bf3c-torque reduction 4th to 3rd downshift
7bf5e-torque reduction 1st to 2nd upshift
7bf80-torque reduction 2nd to 3rd upshift
7bfa2-torque reduction 3rd to 4th upshift
7bfc4-torque reduction 1st to 2nd performance upshift
7bfe6-torque reduction 2nd to 3rd performance upshift
7c008-torque reduction 3rd to 4th performance upshift
7c04c-1st to 2nd normal shift line
7c06e-2nd to 3rd normal shift line
7c090-3rd to 4th normal shift line
7c0b2-2nd to 1st normal line
7c0d4-3rd to 2nd normal line
7c0f6-4th to 3rd normal line
7c118-2nd to 3rd cruise shift line
7c13a-3rd to 4th cruise shift line
7c15c-3rd to 2nd cruise shift line
7c17e-4th to 3rd cruise shift line
7c1a0-1st to 2nd d2 normal line
7c1c2-2nd to 3rd d2 normal line
7c1c4-2nd to 1st d2 normal line
7c1e6-3rd to 2nd d2 normal line
7c1e8-1st to 2nd dlo normal line
7c1ea-2nd to 3rd dlo normal line
7c1ec-2nd to 1st dlo normal line
7c1ee-3rd to 2nd dlo normal line
7c2bc-1st to 2nd hot normal line
7c2de-2nd to 3rd hot normal line
7c300-3rd to 4th hot normal line
7c322-2nd to 1st hot normal line
7c344-3rd to 2nd hot normal line
7c366-4th to 3rd hot normal line
7c388-1st to 2nd performance shift
7c3aa-2nd to 3rd performance shift line
7c3cc-3rd to 4th performance shift line
7c3ee-2nd to 1st performance shift line
7c410-3rd to 2nd performance shift line
7c432-4th to 3rd performance shift line
7c454-1st to 2nd wot shift
7c456-2nd to 3rd wot shift
7c458-3rd to 4th wot shift
7c45a-2nd to 1st wot shift
7c45c-3rd to 2nd wot shift
7c45e-4th to 3rd wot shift
7c460-1st to 2nd hot WOT shift
7c462-2nd to 3rd hot wot shift
7c464-3rd to 4th hot wot shift
7c466-2nd to 1st hot wot shift
7c468-3rd to 2nd hot wot shift
7c46a-4th to 3rd hot wot shift
7c46c-1st to 2nd performance wot shift
7c46e-2nd to 3rd performance wot shift
7c470-3rd to 4th performance wot shift
7c472-2nd to 1st performance wot shift
7c474-3rd to 2nd performance wot shift
7c476-4th to 3rd performance
7c482-1st to 2nd shift rpm
7c484-2nd to 3rd shift rpm
7c486-3rd to 4th shift rpm
7c488-1st to 2nd hot shift rpm
7c48a-2nd to 3rd hot shift rpm
7c48c-3rd to 4th hot shift rpm
7c494-1st to 2nd performance shift rpm
7c496-2nd to 3rd performance shift rpm
7c498-3rd to 4th performance shift rpm
7c4a0-1st to 2nd dlo urban line
7c4c2-2nd to 3rd dlo urban line
7c4e4-2nd to 1st dlo urban line
7c506-3rd to 2nd dlo urban line
7c77a-TCC apply 2nd normal
7c79c-TCC apply 3rd normal line
7c7be-TCC apply 4th normal line
7c7e0-tcc release 2nd normal line
7c802-tcc release 3rd normal line
7c824-tcc release 4th normal line
7c846-TCC apply 3rd cruise
7c868-TCC apply 4th cruise
7c88a-tcc release 3rd cruise
7c8ac-tcc release 4th cruise
7c8ce-TCC apply 2nd hot
7c8f0-TCC apply 3rd hot
7c912-TCC apply 4th hot
7c934-tcc release 2nd hot
7c956-tcc release 3rd hot
7c978-tcc release 4th hot
7c99a-TCC apply 2nd performance
7c9bc-TCC apply 3rd performance
7c9de-TCC apply 4th performance
7ca00-tcc release 2nd performance
7ca22-tcc release 3rd performance
7ca44-tcc release 4th performance
7cc76-normal tcc release %tps threshold vs gear vs speed
7ccdc-cruise tcc release %tps threshold vs gear vs speed
7cd42-performance tcc release %tps threshold vs gear vs speed
7cda8-1st to 2nd normal shift time
7cdca-2nd to 3rd normal shift time
7cdec-3rd to 4th normal shift line
7ce0e-1st to 2nd performance shift time
7ce30-2nd to 3rd performance shift time
7ce52-3rd to 4th performance shift time
7cfa6-shift switch type
7cfa8-disrete switch debounce time
7cfb8-iat sensor present
7cfb9-shift quality controled by pcm
7d002-abuse mode control method
7d004-max turbine torque tcc locked
7d01e-max turbine torque tcc unlocked
7d0a6-brake torque limit
7d1c2-torque abuse speed enable
7d1c4-torque abuse throttle enable
7d1c8-torque abuse rpm enable
7d1ca-torque abuse time enable
7d1d2-torque management engine speed limit
7d1d6-torque abuse spark retard
7d208-torque abuse differential score MPH threshold
7d260-catalyst protection boost shutoff
7d2c0-traction control enable coolant temp
7d50c-transmission type
7d516-1st gear min rpm/vehicle speed ratio vs MPH
7d520-2nd gear min rpm/vehicle speed ratio vs MPH
7d544-speedometer input pulse per revolution
7d558-pulses per mile
7d568-vtd present on car
7d572-vtd injector disable time
7d578-vtd auto learn timer
7d580-vtd autolearn counter
7d632-tcc slip test fail slip rpm low
7d634-tcc slip test fail slip rpm high
7d659-tcc slip diagnostic disable rpm
7d65a-tcc slip diagnostic enable rpm
7d8d0-max shift pressure
7d8d2-drive sprocket ratio
7d8f6-first gear ratio
7d8f8-second gear ratio
7d8fa-third gear ratio
7d8fc-fourth gear ratio
7d8fe-reverse gear ratio
7e942-trans abuse mode-min tp%
7e93e-trans abuse mode-min rpm
7e940-trans abuse mode-max trans rpm
7e946-trans abuse mode-max MPH
7e948-trans abuse mode-torque reduction
7ed76-downshift delay after tcc unlock
7ee0c-tcc upshift unlock time vs gear
7ee14-tcc downshift unlock time vs gear
7efaa-tcc dc max-line pressure vs trans temp
7f9ce-FMC vs CLP vs Temp
7fb22-extra line pressure from dtc
7fffa-prom id
6ee51-car type
6ee56-engine type
6f840-default baro
71202-p1112 min mph
71204-p0113 min ect
71208-p0113 max mph
7120a-p0113 min ert
7120e-p1112 min ert
712b4-p0121 min ect
712b6-p0121 min ert
72a26-p0101 max map
7469c-fan 2 temp
75416-pe a/f vs tps
75a92-pe anable tps
75f16-LTFT min ect
7676a-max STFT
76772-min ftft
7af92-integral gain
7fffa-prom id
So, I started looking into this again, this was a somewhat informative video. I obviously have a ton to learn if I'm going to make any changes, and I'm not sure I'll actually mess with this, but I thought I would share for S+G.
https://www.youtube.com/watch?v=iU_yiOW ... l=Turbo_V6
This page also seems quite helpful so far, I've barely skimmed the first few pages though.
https://mrjester.hapisan.com/04_MC68/
Didn't Turbo v6 let the cat out of the bag yet?
Not sure what you mean? I know he's going to run a 3800 with special crank and cam sensor arrangements on an 0411.
cnp ignition for the v6. He has done some really cool stuff with the stock block s-10. Getting the v6's to run on the the 411 with the custom boost "os" that he made is insane.
it is, he has done lots of cool stuff with the P01 and P59, it's worth mentioning that this thread is almost 10 years old and predates most of that, and that my knowledge and skill levels with programming are poor at best. this thread is just a spot for me to share resources that I find, and for me to document what I learn to some degree.
longshot, but has anyone here seen this with a DHP powrtuner?
the interface will read the PCM, but not read DTC's, or datalog anymore for some reason. I'm using an AVT 852 cable.
