Will the ICM and Pick Up work?
Identity Crisis
Post by Identity Crisis »
I am rebuilding the Stock 2.8L Distributor and I am trying to find all the replacement parts needed.
Can anyone tell me if this MSD ICM/Pick up will work in our Distributors? It says it is for the 4.3L Dist., but I do know that they are very close to the same.
http://www.msdignition.com/Products/Acc ... /8367.aspx
Thanks for the knowledge.
BULL
2014 Dodge Ram 1500 Sport
1992 Pontiac Grand Prix STE
1987 Pontiac Fiero GT
1986 Pontiac Fiero GT
jelly2m81
Re: Will the ICM and Pick Up work?
Post by jelly2m81 »
It's not plug and play, the 2.8 ICM has 2 pins in the back side that the pickup coil (PU ) plugs on to, also the PU on that 4.3 assembly isn't compatable with the Fiero distributer. I susposed one could cut and solder the Fiero pick up coil leads to the 4.3 ICM but that seems to be more work than it's worth seeing the Fiero ICM works fine.
Then there's the circuitry / electronics compability between the 2 if it's the same or not, again it's not worth the effort to find out.
Identity Crisis
Once again thanks for the experience and sharing of the knowledge.
