Fiero HVAC is it....?
- Identity Crisis
Is the Fiero HVAC, an electronic unit, vacuum or cable controlled?
I never liked the way it looked and I am trying to figure out if it can be swapped out with another unit, be it from a Pontiac, other manufacturer or a universal unit from after market.
Cheers
BULL
Cheers
BULL
2014 Dodge Ram 1500 Sport
1992 Pontiac Grand Prix STE
1987 Pontiac Fiero GT
1986 Pontiac Fiero GT
Re: Fiero HVAC is it....?
An electric motor servo controls the system.
- Identity Crisis
Thanks. Then I should be able to use a Pontiac Grand Prix unit. I dont have AC and I am not adding it either.
The cold air / heat door is cable operated. If you can find a HVAC control head with a similiar setup it should be easy to convert.
EDIT:
If your car does'nt currently have AC then the doors are all cable actuated.
EDIT:
For clarification, cars that were shipped without AC from Pontiac came with a double slider panel, with two cables operating both temperature selection and vent selection. This was sort of a rare option though. Most cars have the slider for heat selection, and the buttons above it for vent selection - the slider controls a cable, the buttons of course control a servo.
There have been several retrofits, Grand Am and the like I think. It's time consuming. These guys who swap interiors, engines, electronics, etc might as well purchase a new car, they're throwing that much time to the wind on something that's worthless. But they're the ones who have changed the head unit.
I would guess the majority of Canadian Fieros came with the manual sliders. Of the 6 Fieros I had, only 1 used the push buttons.
Good point, who's needs AC in Kanada? And you're both up there, so good chance he'll run into a few. Its the opposite down here, I've seen one double slider unit ever.
I don't think I've ever seen a non-AC Fiero!
Nor have I, and I've owned a handful of absolute base model iron duke garbage parts cars. The 10k mile 84 I have is a steel wheel, crank window, manual lock, 4speed car, and its got AC.
Kru had an orange 88 coupe w/o AC. It was the first one I had seen w/o and the last I have seen as well.
- Identity Crisis
I could take a pic if you like?
First time in the history of all time that a non option is an option?
- Identity Crisis
- Identity Crisis
Yes it does seem that this is an oddity..
- Identity Crisis
Now I can not find gauge overlay to work with this...
I think I've seen all of two non-A/C cars... obviously never owned one.
