262's 1970 GMC
Re: 262's 1970 GMC
Why do you need an engine swap? Doesn't it have a 400? Drop a HSR with AFR 205's on it with MS2 or MS3 and go to town! :-D
Re: 262's 1970 GMC
The Dark Side of Will wrote:Why do you need an engine swap? Doesn't it have a 400? Drop a HSR with AFR 205's on it with MS2 or MS3 and go to town! :-D
It does have a 400, and runs better then the 327 the other(is that the right word? they're kinda one in the same now...) truck had. it's not really why I went forth with all of this though. the 400 does sound like a nice little engine for a 1987-92 firebird though...
CincinnatiFiero
Re: 262's 1970 GMC
Post by CincinnatiFiero »
ericjon262 wrote:like brighter headlights(with relays)
Can you get like Cibie or Hella H4 conversion housings? That what all the Benz guys do, the best sealed beam in the world is still crap IMO. Need to get composite housings.
Re: 262's 1970 GMC
sure can, it's just a 5.75" sealed beam, and plenty of companies make conversions.
Re: 262's 1970 GMC
Started drawing up mounts for the vortec swap...
first run looked good, but was flawed in more way then one... it was designed around stock rubber mounts, but seem to be impossible to find without going to the dealership. I also made them way too tall. and one side also intrudes too far into the engine compartment.
Revised is designed around GM RWD transmission mounts which are available anywhere, cheap, in solid, rubber, or poly. I've also designed them so the laser cut pieces will interlock, to make welding much easier.
only done with the passenger side so far, and it's not really 100% yet.
Re: 262's 1970 GMC
What CAD program?
Re: 262's 1970 GMC
The Dark Side of Will wrote:What CAD program?
Google Sketchup. seems decent for freeware.
Re: 262's 1970 GMC
Interesting... I must be lame. I tried that and thought it was crap... maybe I just didn't "get" the interface.
Re: 262's 1970 GMC
The Dark Side of Will wrote:Interesting... I must be lame. I tried that and thought it was crap... maybe I just didn't "get" the interface.
It's gone through a couple of updates since I used it last, I don't have much experience with CAD programs though...
Re: 262's 1970 GMC
I've tried Sketchup a few different times over the past few years, most recently a couple months ago, and could never figure out how to make anything useful. I use Solidworks regularly though.
Re: 262's 1970 GMC
Series8217 wrote:I've tried Sketchup a few different times over the past few years, most recently a couple months ago, and could never figure out how to make anything useful. I use Solidworks regularly though.
you guys are probably working with way more complexed stuff than flatstock too though! :-D
Re: 262's 1970 GMC
hopefully 3rd time is a charm. (not done yet...)
Re: 262's 1970 GMC
Little more progress...
I have also found someone who can cut them out for me.
Re: 262's 1970 GMC
about to start on the crossmember.
Re: 262's 1970 GMC
I'm going to have to give sketchup another look... Nice job.
Re: 262's 1970 GMC
The Dark Side of Will wrote:I'm going to have to give sketchup another look...
I think it should work fine for static parts like I am designing.
The Dark Side of Will wrote: Nice job.
Thanks, they're just about done with the design phase now. just a little more work and I'll be ready to send the plans off to the cutter.
Re: 262's 1970 GMC
Decided to go ahead and finish them up...
Done? Hopefully... :crazy:
Re: 262's 1970 GMC
And this is the free version of SketchUp, the demo for the Pro version... Or did you throw down the $600 and pick up the full pro version?
Re: 262's 1970 GMC
The Dark Side of Will wrote:And this is the free version of SketchUp, the demo for the Pro version... Or did you throw down the $600 and pick up the full pro version?
it was the demo of the Pro Version, but you only get to use it for 8 hours (blew through it quick) so now I've been using the free version.
Re: 262's 1970 GMC
As long as the free version can build models like you show AND produce drawings to have a shop make the parts, it sounds like it'll be fine for my uses for now.
To be painfully clear, that's "SketchUp Make", right?
