Dual Plenums for turbos
Re: Dual Plenums for turbos
Interesting, and I stand corrected. I have no clue what duty cycle I'm running, or how long they are opening for, just 42.5# injectors and they don't lean out that's all I know haha.
http://www.jenvey.co.uk/home/turbo-plen ... mm-aplc-70
Jenvey can probably send you additional photos or a basic dimensioned drawing if you ask them nicely.
I'm not sure if this uses the dual plenum arrangement that this thread is discussing... However, even if it doesn't, you could insert a piece of sheet metal with a slot in it between the main plenum and the throttle body mount to achieve the same effect.
