For Sale Lz4/9 Cam bearing spacers
Posted: Thu Oct 15, 2015 5:34 pm
For the gen 4 3.5 and 3.9 liter engines with the 99mm bore. Came in Pontiac G6 and Late model impalas. I had a couple extra made up and offering these to RFT first. These will allow you to use a non vvt cam, in this block.
Aftermarket roller cams are available from Comp Cams. Contact me on how to order a custom cam.
The older cams have a smaller cam journal, so an adapter is needed. These adapters that I had made allow for use of the stock cam bearings in the 2.8-3.5 engines.
I only had a couple extra made on top of what I am keeping so first come first serve. These used to be made by TCE/BCC but no longer available. I am asking $200 for the set of 4. If there is enough demand I can have more made up but didn't want to invest a ton of money up front if no one wants them.
