Update: Got some thrust plates! Thanks Shaun!
WTB 1995 or 1996 (maybe 1997 -- check pic) 3.4 DOHC (LQ1) cam thrust plates, set of 2
Must be from a '95 or newer motor.
Should look like this:
I need two.
Please confirm thickness. I'm doing the camshaft oiling reroute on my motor and need the thinner plates.
WTB 1995+ 3.4 DOHC (LQ1) cam thrust plates, set of 2
Re: WTB 1995+ 3.4 DOHC (LQ1) cam thrust plates, set of 2
Going to post some info on that procedure in one of the threads on your car?
The link in my post above is pretty comprehensive --- was there something else more specific you wanted to see covered?The Dark Side of Will wrote:Going to post some info on that procedure in one of the threads on your car?
Just that it's in a thread in which you've discussed development of your engine, swap and/or car
