changing instrument cluster bulbs
Posted: Mon Apr 03, 2017 11:20 am
by shemdogg
Hows it done? I got a few pieces off, broke the clear bezel, but dont see how the rest comes off. Only the ebrake light and check engine light work. Also fuel gauge not working so thatll need to come out too. Any help appreciated
shem
Re: changing instrument cluster bulbs
Posted: Mon Apr 03, 2017 11:35 am
The back cover of the gauge cluster comes off allowing you to access the bulbs. It is not done from the front per say.
The back cover could be mistaken for a part of the dash but its a removal cover on the backside of the gauges. Its a trim piece is the best I can describe it
Posted: Tue Apr 04, 2017 2:16 am
by shemdogg
ok I got it off but how do I get the fuel gauge out? Any common thing to look for first?
shem
Posted: Thu Apr 06, 2017 5:01 am
by FieroWanaBe1
The bulbs are just screwed into the back of the cluster with a round barrel shaped plug that has a flat extrusion across the diameter. No need to remove gauges. Just remove the trim piece on the back side and unscrew the bulb socket to change.
