I know how to measure VE. I just want to cheat.
Gixxer wrote:This is how you do it.
Take your engine, or car to the appropriate dyno.
Not an inertial dyno, a real dyno, that holds the engine at a fixed RPM under load.
Hook up the intake side to a mass airflow meter.
Run the engine up to the specific RPM point that you're interested in, at full throttle.
Start the MAF readings and a stopwatch at the same time.
Stop the MAF readings and a stopwatch at the same time.
Since you now know the volume of air ingested by the engine, and you should know the swept volume of the cylinders, and the amount of time, which corresponds to the RPM (revolutions per minute)..
You can now calculate the VE of the engine knowing that you don't have to worry about internal engine drag, drivetrain losses, etc.
Ain't I smart?
BTW, I think this is the way the OEMs do it.....Ask Cali Kid, the doorknob guy.
