if someone with a manual installed in an 88 cradle could measure the distance from the cradle frame rails to the output of a five speed transmission (bonus points if it's an F23) I would appreciate it more than you could imagine.
pictures are for example of the measurement I'm looking for. both sides would be awesome.
88 cradle measurement help
Re: 88 cradle measurement help
My '88 has the front end up right now; I might get it back down next weekend.
I can prob do it
My axle is still in so measureing from the esge of that axle seal wont happen.
However I measured from the flat surface next to the seal. I got 18.25 inches.
Thats where your 30 cm mark is at on your ruler. As I measured to the inside of the rail.
Awesome, I assume you measured at approximately the axle centerline height to the top of the inside of the rail?
I appreciate the help!
